Too Many Heads
Old Dec 22, 2000 | 12:23 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Too Many Heads
Hey guys, i would like to keep my stock cam and intake and just replace my old heads with the new one's.
What would be the best heads for the car for less than $1000.
Please look below to get an idea what I have.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
Old Dec 22, 2000 | 04:37 AM
Pat Hall's Avatar
You'd be wasting your money buying a good set of heads without adding a good camshaft to go with it, not to mention some porting on your intake pieces would be beneficial as well. If you're going to retain your stock camshaft, you might as well save a ton of money and just have your original heads freshened up.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 22, 2000 | 02:33 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Daniel,
You should really look to the World Product S/R 305 head, which is around $650 a set. In addition, please consider getting a new cam. $160 will buy a nice one. Finally, while you are in there, consider a higher stall converter. Turbine Technologies makes a good one for the price: $160. I'm using one and cut 4 tenths off my quarter mile. You'll like it, I'm sure.
All up, the changes I've recommended will come in at a few bucks over $1000, and you'll have a responsive, fun car.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
[This message has been edited by ws6transam (edited December 22, 2000).]
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
