could it be head gasket
Old Nov 19, 2003 | 08:17 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i, a month ago i replaced my head gaskets and now when it is cold and i smash on the throttle and get off it i smell coolant and see it coming out the exhust pipe for like 3 min then it will stop could it be a head gasket problem and it is not overheating help before i take down and it is not the gaskets.
Old Nov 19, 2003 | 08:33 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
coolant out the exhaust? or is it just water?
If it's coolant then yes it could be a head gasket or a crack in the head.
Old Nov 19, 2003 | 10:08 AM
antoine's Avatar
yes it is coolant but why it smokes when cold and why it smokes when i get on it but normal driving it does not smoke.
Old Nov 20, 2003 | 12:19 AM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
could be the intake manifold gasket too. The coolant flows through it close to the front two intakes. I had a coolant leak in my gasket (leaked out the front as opposed to toward the cylinders) but it only showed itself when I drove it hard - i.e. when it built up enough pressure in the cooling system to get past the gasket seal.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
