What kind of intake is a raised port style manifold? n/m
Old Dec 23, 2000 | 07:11 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
n/m
Old Dec 23, 2000 | 07:16 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The ports are up higher, nearer the valve cover flange. Some of the older Bowtie heads and the Vortecs and Fast Burns are made that way. It allows the intake charge to follow a straighter path into the clinder, less of a turn at the throat right before the valve.
Old Dec 23, 2000 | 07:53 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
What are they called in Jegs? how do I know I'm buying a raised port manifold? Are they the center bolt valve cover ones? Or are the vortecs the only ones that will fit?
Old Dec 23, 2000 | 08:00 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Why do you think you need raised ports? Do you have aftermarket cyliner heads with raised ports? If you have raised port heads, then you need a "raised port intake manifold".
Center bolt is totally different, it refers to the valve covers and not the intake ports.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
Chevy Info --> MadMike's
Old Dec 23, 2000 | 09:42 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I want to buy the GM "fast burn" heads. GM says they accept either vortec or raised style intake manifolds. My question is: where would I find a place that sells these intakes? I have never seen a place selling them.
I know center bolt is the valve covers, BUT center bolt valve cover heads require a different intake than the standard ones.
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam.
Old Dec 23, 2000 | 10:49 PM
327 firebird's Avatar
I don't know about that but I know with summit, the sales people are very knowageable aout the products and what they will fit. If they don't know the guys on their tech line do know. Give them a call and I'm sure they will be able to tell you
Old Dec 24, 2000 | 12:23 AM
MRZ28HO's Avatar
Engine: was: L69
What kind of intake (ie: carb'ed or TPI)? For carb'ed look at Jegs, Summit, PAW, etc ... Edelbrock makes "raised port" intake manifolds, so does Weiand/Holley, TFS, etc ...
No, they do not. Canted intake bolt heads do, which are '87 later cast iron heads (B2L/LB9/LO3). The Corvette aluminum heads (true L98) are center bolt, yet require standard intake bolt pattern.
[This message has been edited by MRZ28HO (edited December 23, 2000).]
Old Dec 24, 2000 | 09:20 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Hope your purpose here is to help not contradict sir, you know what I meant. This is an F-body board not a corvette board, therefore I would be talking about the cast iron ones. END OF STORY.
Old Dec 24, 2000 | 09:53 AM
md's Avatar
md
Raised port heads do not necessarily require center bolt valve covers. AFR 195's, a couple Darts, Canfeilds, a couple Brodix heads, etc... come to mind.... Be carefull not to confuse raised port heads in general to what you need. You need a post 96' "vortec" gen I style intake for those heads. The manifold will mate with the raised port location and have the same bolt pattern, which is different with the vortecs and fast burns.
Edelbrock makes a Performer, Performer RPM, Vic JR and Super Vic that will bolt right up. Just look at their web sight, I'm sure they have the part numbers listed. Just look for a post 96' "vortec head" manifold. And make sure it's a GEN I and not LT1 or LT4 because they have a different coolant flow path.
Mike
Old Dec 24, 2000 | 06:40 PM
MRZ28HO's Avatar
Engine: was: L69
Listen "buddy", all that I said is based on what you were asking. No contradiction what so ever! I am here only to help other F-body enthusiast like myself and not as a flamer (like some people). I don't know what you meant, I know what you typed. Based on that I responded, next time be more specific. I know this is an F-body site, but people do use the L98 heads on their F-bodies (both 305 and 350). Also, fact is there are some center bolt heads that do have the standard intake bolt pattern, and not the canted bolt pattern. Don't take post personal, people are trying to help others and sometimes we don't know the level of expertise we are dealing with. I at least try to cover all the bases so there is not a misunderstanding on the side of the post'er. Now, end of story!
stalkier
Dec 6, 2015 11:25 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
