Cranks!!!!!!!!!
Old Nov 21, 2003 | 05:21 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
Cranks!!!!!!!!!
ok i'm starting my 350 buildup. I'm starting with a shortblock that i don't have to worry about.
i would like to go with a forged steel crank. What # steel should i be looking into getting, who makes good ones and who makes bad ones. I don't want to spend 4200 on a crank i know it isn't what i want but i also don'tt want to spend over $1500 on a callies.
I'm looking at spending around $500 on a crank. With that said what do you guys suggest? the motor will start out as a 350 w/ sportsman II heads and a cc305 w/ maybe a 100 shot.
I was thinking about a 4340 forged steel crank. It must be able to handle saftly 500hp and handle 7500rpm.
thanks Jonathan AKA WyClef
Old Nov 21, 2003 | 05:53 PM
85TransAm406's Avatar
Car: 1985 Trans Am
i'm runnin an eagle 4340 3.75 inch stroke crank, internally balanced, i love it. ran me around $450. Just shop around, Jegs and Summit are around $200 more than you can find them for from other dealers.
Old Nov 21, 2003 | 09:39 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You don't need a 4340 crank a 5140 will be fine and be about 40% cheaper.
Old Nov 22, 2003 | 12:24 PM
Engine: peanut LB9
thanks, if the shop won't charge me alot more cash to machine teh block i might go w/ a 383
Old Nov 22, 2003 | 06:48 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
I just picked up a forged steel crankshaft from my local machine shop (jesse miller machine, nationally recognized), and they took it 10/10, cleaned did all the work a day before I picked it up, and it was a one peice rear main seal, and I got it for $345. That's where i'd start, is the local machine shops (but not uncle paul's shop).
Old Nov 23, 2003 | 05:25 PM
Engine: peanut LB9
i would uch rather go to a local shop around here but there only about 2!!!, i don't trust one of them (lots of horror stories and lots of BS) and the othe rone wants around 15grand to swapa 350 and a tranny into mycar w/ all the works. i can do it for around $11k including shiping.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
