Deafining backfire
Old Nov 22, 2003 | 03:34 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
Deafining backfire
I just put headman lt's into 4" dynomax race mufflers i changed the plug wires but didnt cut them and elimated o2 sensor. now i have backfire and its really loud so i cant stay outside the car or else i'll go deaf. is it because i took out the o2 sensor or something else and how do i fix it? my cars an 84 firebird with carbed 305. it doesnt backfire at idle or it i rev it up slowly and it idles bad in gear.
Old Nov 22, 2003 | 04:23 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
If it's backfiring through the exhaust it sounds lioke a maybe 2 wires are switched around
Old Nov 22, 2003 | 04:25 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
yea thats what i originally thought but i was pretty sure i goy them right but i'm gunna go check now
Old Nov 22, 2003 | 05:23 PM
onebinky's Avatar
My guess is on the backwards wires too. It's real easy to get a couple backwards if you don't mark them or double check all of them before you fire it up
Old Nov 22, 2003 | 05:44 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
yep i had two wires switched up only poped once after i changed it. but it still idles kinda jumpy in gear like from 400-800rpm but the problem i really wanted fixed is done so thanks.
Old Nov 22, 2003 | 07:19 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
you run a computer controlled carb? why on earth would you remove the oxygen sensor? removing the o2 sensor is going to cause a lot of problems.... its there for a reason.
Old Nov 22, 2003 | 08:05 PM
87LTcamaro's Avatar
yup O2 sensor is kind of important
Old Nov 23, 2003 | 11:16 AM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
i had to take it out to put in the headers and i had no where to put it back in. but im switching to non cc carb and eliminating the computer completely. i also had to cut the knock sensor in half because it rubbed against the headers.
Old Nov 23, 2003 | 01:25 PM
Car: '89 IROC-Z
I dont even think I'd drive it until I switched... No o2 sensor is bad enough. No knock sensor is even worse.
Old Nov 23, 2003 | 01:27 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
yea well it doesnt get driven anyways just started and pulled in/out of the garage.
Old Nov 23, 2003 | 08:13 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Technically;
Back-fire is an explosion back through the intake manifold.
After-fire is an explosion out the exhaust.
Without the 02 sensor, the ecm will stay in open loop, and probably run too rich.
Old Nov 24, 2003 | 02:44 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
yea so pretty much im just switching to a a normal 600cfm holley and hope that will cure my idle problems.
tyeo098
Nov 30, 2015 06:27 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
