Running a little rich
Old Dec 26, 2000 | 11:29 PM
irocbsa's Avatar
Showing no codes. Just replaced a CTS. At idle there is a good amount of fuel smelling "smoke" coming out of the pipes. Its cold so I figure for a little but this looks to be a bit excessive. I'm positive its not a head gasket as it does not smell like coolant and I just had the heads off. It was doing this before I had them off so I didn't ding the gaskets in an improper install.......
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Dec 27, 2000 | 05:03 AM
Pat Hall's Avatar
I noticed in your sig you have 23 lb. injectors. I'm assuming you have an adjustable fuel pressure regulator. Have you tried playing with your fuel pressure? Also, I've heard if you're still running a stock chip with bigger injectors, it can cause them to run richer at idle.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
[This message has been edited by Pat Hall (edited December 27, 2000).]
Old Dec 27, 2000 | 12:51 PM
irocbsa's Avatar
You knwo I was thinking that. I do not have an AFPR. I've been meaning to get one. I have an aftermarket chip from Street and Perf. Its their stage 1 performance chip. Maybe this isnt aggressive enough.
bsa
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
