Block decking, and head alignment
Old Dec 5, 2003 | 11:39 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
If you have a block decked how much material needs to be removed, before you have to have the heads, remachined to align with the intake.
My 400 needs 30 thousandths removed.
Spud
Old Dec 5, 2003 | 12:12 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
My block was 0-decked and required no machining to the intake or heads for them to align.
Old Dec 5, 2003 | 02:00 PM
ede's Avatar
ede
i've never had a problem with intakes when i removed metal from the block. just got a set of heads and pick up block next week that have both had metal removed so i'll see what that does
Old Dec 5, 2003 | 02:12 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
There is a formula for that. But I'll be damned if I can remember it now. I'll look through some notes.
0.030 is quite a bit, but I don't think you'll have any major problems.
Old Dec 5, 2003 | 02:52 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Your block should have come from the factory approximately with a 9.025" deck. 030" would probably put you below 9" which is the standard that most pistons are set for as far as comp. height. Your pistons will probably be just above the deck after being machined.
The standard accepted head deck to block deck clearance for steel rods is about .035". To maintain this on a block decked below 9", you will have to run a fairly thick head gasket to maintain that .035" clearance. Any quality head gasket in the .045" to .060" range would be good. DO NOT RUN A SHIM GASKET AFTER YOU GET THE BLOCK BACK!!
You also might consider running the Moroso plug deck stiffeners. They are just a NPT 3/4" plug with a 5/16" hole for head cooling. Typically, because I use my cars just for street use, I will drill these out to about a .400" hole. I like the deck strengthening but like my heads to cool normally.
Old Dec 6, 2003 | 01:32 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Straight from John Lingenfelter's book
John Lingenfelter on Modifying Small-Block Chevy Engines, pg. 95
Anytime either the block deck surface or cylinder head dack surface is machined, this changes the relationship of the intake manifold and cylinder head sealing surfaces. To restore this relationship and improve intake manifold gasket sealing, it's often necessary to mill both intake port sealing surfaces as well. If the heads and/or block is milled less than .020-inch, milling the intake is usually not necessary. All dimensions are in fractions of an inch.
Block/Head.................Intake Manifold
....................................Side...Bottom
.010---------------------.012----.017
.015---------------------.018----.025
.020---------------------.025----.034
.025---------------------.031----.043
.030---------------------.037----.052
Old Dec 7, 2003 | 10:44 AM
spud's Avatar
Engine: 400 & 355
I have that book, Maybe I should have a refresher course, and re read it.
John
Jake_92RS
Jan 28, 2020 10:37 PM
deracer
Apr 11, 2016 12:04 AM
383backinblack
Aug 15, 2015 06:36 PM
rithsleeper
Aug 11, 2015 07:55 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
