What is a pintle?
Old Dec 6, 2003 | 08:05 PM
AstroturfHead's Avatar
What is a pintle?
Hi guys I'm trying to clean my IAC, what is a pintle? Can somebody describe how to remove it in grater detail? Thanks!
Old Dec 6, 2003 | 11:38 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The pintle is the portion of the IAC that moves down the machined seat on the tbi and closes off the passage. Its powered by a small stepper motor inside the housing. It can be removed, but the easiest way to clean it is just with a toothbrush and some gentle solvent, like naphtha or carb cleaner, and brush the carbon deposites off. Lubricate the shaft that leads into the housing with a few drops of motor oil after cleaning. The pintle is the cone shaped machined portion sticking out of the IAC housing in the picture below
Old Dec 7, 2003 | 11:28 AM
Vader's Avatar
The pintle is in the upper right quadrant of each of these examples:
Incidentally, it only takes that much dirt (upper photo) to completely kill the IAC's responsiveness.
Old Dec 7, 2003 | 11:54 AM
alright, thanks. I cleaned mine and reset all the sensors and now it idles GREAT. thanks guys.
beatercoprice
Nov 26, 2006 05:43 PM
IROCBlueZ28
May 1, 2005 11:07 AM
IROCBlueZ28
Apr 30, 2005 09:38 PM
TomP
Apr 24, 2003 12:37 PM
Vader
Mar 16, 2002 10:58 AM
