Need help buying Car, Confused on engine
Old Dec 6, 2003 | 08:09 PM
I-needto-rock's Avatar
Car: old junk
Engine: even older junk
Transmission: used to be a 5 speed till 4th blew out
I am looking into buying a so called 90and 1/2 Irocz camaro. To make it short ill start. The guy said it was a kit car and he saved 5grand buy putting it together himself. Is that B.S.. Also he said it had a tpi 350 in it but I poped the hood and it looked like a carbed small block, it had a black cast intake manifold and a round old style carb air cleaner. Could it be a 305 tbi? how do you tell the difference between Carbed, TPI, and TBI. It sas z28 and iroc on the dash and Irocz on the sides under the door the engine bay is red and the exterior is white and needs a paint job bad. also the bumper sas irocz. It is a 5 speed convertable. Also I have a book Muscle car chronicle and it sas all Irocs were 350cubes I am confused on this one Any help would be aprecciated
Old Dec 6, 2003 | 08:30 PM
Car: old junk
almost forgot. The registration is for a 82 comaro I asked what that was about and he said "hey im Itailian, got a brake on insurance Irocs cost more" did they make droptops in every production year, that same book sas no but i have found quite a few screwups in it. Again any help would be aprecciated
Old Dec 6, 2003 | 08:53 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
It could be many things. Sounds like a hodgepodge of parts to me. Get the VIN # and run it on the decoder found on this site.
If the 8th digit of the VIN # is a "8" or an "F" then its a TPI. "8" is TPI 350, and if its a "F" then its a TPI 305.
If the engine don't look like the pic below, its not a TPI. No matter WHAT he says.
TPI looks nothing like ANY carb I've ever seen. Below is the first picture I ever took of my engine. This was before I even owned the car. hasn't changed much since then, its just a little cleaner. Its a TPI 350
I have one suggestion for this car. STAY AWAY FROM IT. There are too many holes in this guys story.
Old Dec 6, 2003 | 09:04 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I never heard of a kit car Camaro.
All real Chevy Camaros are biult complete on the assembly line.
This guy is giving you a bunch of BS!!!!!!!!!!!
Old Dec 6, 2003 | 09:21 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
RUN and I mean RUN, don't look back just keep going. That guy must have seen SUCKER stamped on your forehead.
Old Dec 7, 2003 | 02:46 AM
377ciTT's Avatar
Car: 94z28,84 3rdgen no engine,64 vette
Engine: lt1,-,350
Transmission: t56,-,m4
yea i definitely agree but heh when i was a little younger and wanted a camaro i would have bought it anyway =)
check this out www.traderonline.com you might be able to find something nicer in here without an a-hole used car salesman (even if he isnt at a dealeer he soundsl ike one)
Old Dec 7, 2003 | 10:57 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It's a peiced togather car, the only thing it has going is it being a convertable. It sounds like a stolen car with a different vin plate or one that was wrecked and patched from 10 different cars. You need to find out if the title is good, probably not. I'd buy it reguardless but I dont suggest you do.
Old Dec 7, 2003 | 02:51 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
I wouldnt give a nickle for that car....sounds like total BS..yea use traderonline to find cars in your area.
And the only carb setup I seen that looked SIMILAR to a tpi is a carbureated centrifigal supercharger, and it only looked VAGUELY similar.
RazorN8
Jan 7, 2022 11:44 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 11, 2015 03:17 PM
MENINBLK
Aug 5, 2015 11:58 PM
