Pulling Engine
Old Dec 7, 2003 | 05:48 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Pulling Engine
The time has come for me to pull my engine (305 mounted to a 700r4) so I can put in a yet to be bought 350 and t56.
What is the best way to remove an engine?
What about wiring and everything?
How much time should I set aside to do it?
Should I drain the car of fluids?
Is there anything I should keep in mind when taking the engine out?
And also, I know some jobs are a lot easier to do when the engine is out. So taking advantage of having no engine what projects should I try to complete with an empty engine bay?
Any other advice suggestions?
Old Dec 7, 2003 | 06:13 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
if u dont have the garage space, take the tranny out first..
engine pulling is easy, make keen note of electronics n where they go, what plug is for what (alot of people take pictures)
the job will take prolly 5 hours if... its not that hard
i would drain the radiator, you'll need to remove that (or risk smashing it)
u using a cherry picker? watch the distrib cap/ oil sending unit, anything in the back... take it slow n take your time, you'll be fine..
also do a search here for engine removal hints, you'll find a ton more that you'll feel like you've done it before =]
good luck
Old Dec 8, 2003 | 04:44 AM
ede's Avatar
ede
drain the coolent, unplug sensers and senders, remove distributor, remove ac and anything else you can off front of engine, remove radiator, unbolt exhaust and motor mounts, i like to leave auto trans attached to engine
Old Dec 9, 2003 | 07:39 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
When pulling eng and tranny together, I like to remove driveshaft and place a plastic bag over tranny tail shaft. Secure it rubber bands.
If you don't, when you tilt the eng/tranny up, you'll have tranny fluid all over the place.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
