can a bad throttle position sensor cause this?
Old Dec 11, 2003 | 04:20 PM
91RSRob's Avatar
Car: 91 Camaro RS
Engine: Stock 305 TBI
can a bad throttle position sensor cause my fuel injectors to stop spraying at idle?
i have to spray starter fluid in the throttle body to start it, and then it will only stay running if i keep the rpm's above 1000.
my car has about one year old cap, rotor, plug wires, plugs, fuel filter, and fuel pump on it. i started the car, and watched the injectors, as soon as the rpms fall below 1000, the injectors stop spraying.
any input would be greatly appreciated, going to work and school with no car kinda sucks .
Old Dec 11, 2003 | 09:45 PM
91RSRob's Avatar
Car: 91 Camaro RS
so i just checked the tps with a digital voltmeter....
reads .44volts at idle, and 4.16volts full throttle.
is .44v too far from .54v to keep the engine running, or is it just the voltmeter being that far off?
Old Dec 12, 2003 | 01:10 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I really don't know if the voltage being at .44 can cause it not to idle, but I would say you should set it correctly. Mine is set at .53 at idle... which runs fine, but it still should be set properly.
I would also check the ECM for codes, see if you're getting any.
Old Dec 12, 2003 | 05:16 AM
91RSRob's Avatar
Car: 91 Camaro RS
i've heard that on my 91 rs they used a non-adjustable tps?.
and im not getting any codes. i believe the ecm to be working since it throws a code when i disconnect my map sensor.
Old Dec 12, 2003 | 06:00 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Non adjustable.. correct.. however it is adjustable if you drill the holes a bit larger/oblong. People have done it and it works just fine.
If it originally was a 89 and earlier it needed to be adjustable. In 90 - 92 the SD units had a self initalizing test where it automatically reverts to the low setting when it is started with the throttle plates all the way closed.
Old Dec 12, 2003 | 08:43 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
fix it yet?
Old Dec 15, 2003 | 02:39 PM
91RSRob's Avatar
Car: 91 Camaro RS
well we figured it out.
first i tried a new IAC valve, but that didn't help. my buddy had an old control module laying around, so we tried that. put it in and tried to start it, got fuel but no spark. so i went to autozone and bought a new one (control module part no. DR140) and it started right up.
it's kinda funny that the two modules had the exact opposite problem. mine would deliver spark but no fuel, and the other one would deliver fuel but no spark.
so old faithful rides again
Old Dec 15, 2003 | 09:58 PM
TekViper's Avatar
Engine: 3.1L v6
ignition control module?? bastard
mdtoren
Aug 23, 2015 12:52 PM
Bryan F
Aug 18, 2015 02:28 PM
mdtoren
Aug 16, 2015 05:45 PM
squiggy2
Aug 9, 2015 09:30 PM
