Engine timing?
Old Dec 11, 2003 | 11:30 PM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Engine timing?
What would be a good total timing to be shooting for in a 355 above 2000-2500 rpm? The 355 has a cam that is 230@.050, a vac secondary Q-junk, 9.4 to 1 compression, and a dual plane intake and headers. Auto trans (2500 stall) and 3:73 gears too. 26-28 degrees total? Or higher/lower? I am installing a new Comp 9000 Unilite distibutor that is a mechanical advance only, and I am wondering what I should be shooting for overall.
Old Dec 11, 2003 | 11:43 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
between 34* and 36*
Old Dec 12, 2003 | 01:19 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
As much as you can get away with and still run on pump gas. Generally it's 34-36 or so, kind of depends on the motor...
Old Dec 12, 2003 | 07:03 AM
ede's Avatar
ede
yeah as much as you can on whatever fuel you run , watch for knock counts with a scanner
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
