Block fill ?
Old Dec 14, 2003 | 04:03 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
Block fill ?
how much fill can you use and still be streetable? how much have you run on the street with out adverse cooling problems?getting ready to build new motor .040 over 400 with 350 crank(see sig)
mike
Old Dec 14, 2003 | 05:13 PM
85TransAm406's Avatar
Car: 1985 Trans Am
I've ran a tall fill in my 383, and i've got a short fill in the 406. No problems on the street at all, just make sure you have a top notch cooling system, just to be sure. i've been thinking of goin to a tall fill in the 406 when i put in the splayed main caps, i don't think it will be a problem, even though i don't know anyone runnin a tall fill in a 400 (street). I own a set of torque plates, so i fill blocks all the time for my friends, never seen any problems in any of the probably 15 engines.
Old Dec 14, 2003 | 07:55 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
why fill a block?
sorry dumb question i guess!
Old Dec 14, 2003 | 07:56 PM
Car: 1985 Trans Am
to reinforce the cylinder walls.
Old Dec 14, 2003 | 08:02 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
people usually run short fills on the street, just under the front freeze plugs...cooling is supposedly better with a short fill because the coolant stays cooler since it's not absorbing heat from the oil, which performs better at a higher temperature anyway.
Old Dec 15, 2003 | 12:10 AM
automec's Avatar
Car: 82 Z-28
Engine: 408
Axle/Gears: 4.11
i am running the big Be-Cool rad. and fan kit. tha radiator barely fits between the frame rails . and i plan on as much nitrous as nessissary to uhh ummm get to the finish line first. the last motor was in the car when i bought it and i was spraying 300 shot on cast pistons(they were suspos to be forged) they broke on a 350 shot when i didn't pull out enough timing
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
GTAman
Sep 26, 2015 02:01 PM
HikoriYami
Sep 21, 2015 07:11 PM
corey8084
Sep 17, 2015 02:56 PM
RyanJB
Sep 14, 2015 03:39 PM
