Fuel line popped!! Need a new one, HELP!
Old Dec 14, 2003 | 07:15 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
(87 IROC , 5.7 TPI)
Alright so I got this new fuel pump installed.. (holley, 255LPH in tank electric) and the car was running beautifully. Well after coming from the movies, my car wouldnt start and to make a long story short, the hose from either my sending line or my return line under hood basically popped off its connector. The hose is shot, I can't get another one anywhere on a sunday because evidently it is a high pressure hose. Summit laughed at me and told me to hit the dealer. Anyone have an alternative, perhaps even a braided line?
Old Dec 14, 2003 | 08:31 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Yup earl's sells the proper fittings. Check out the thread below. it has all the PN's and pictures
https://www.thirdgen.org/techbb2/sho...hreadid=166305
Old Dec 15, 2003 | 08:06 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Just go to the dealer or junkyard. You don't want anything homemade unless you take you old fittings to a hydralic shop to get new hose professionally installed. They have the proper hydralic crimpers to do the job right.
Remember you're running up to 50psi through those lines and the pumps capable of more then that even...........
Old Dec 15, 2003 | 01:25 PM
Car: '89 IROC-Z
Those fittings and braided line will be stronger than the original 'unsafe' rubber hoses. You can get the original hose from GM but you'll be waiting months. Get one out of a junkyard and you'll be getting ...well, junk.
Old Dec 15, 2003 | 01:35 PM
Car: 1987 IROC Z
Lesson learned....
So I was able to pull that hose from my RS, put it on, and tested the fuel pressure. It seems that I was running at close to 100 PSI. We installed an AFPR prior to having this new pump put on, but couldn not adjust it at the time as we did not have fuel pressure at the time. Right now I am running at about 50. No wonder it exploded.
Old Dec 15, 2003 | 04:25 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
Old Dec 15, 2003 | 04:44 PM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
OMG...outa curiosity...what did your car run like at 100PSI fuel pressure? rough running anywhere or what...just a curiousity that I don't want to have find out on my own. Don't make me do it...cause I will.
Old Dec 17, 2003 | 01:54 PM
Car: 1987 IROC Z
Like demon oddly enough. It only gave me **** on idle. One interesting note was starting the car. I could barely touch the ignition before it turned over. If I did any further, I would over crank it.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
