Is 15 degrees initial timing too much?
Old Jan 6, 2001 | 01:46 PM
chris83z28's Avatar
I bumped my titming to 15 degrees advanced today and ran the can in the quarter. I pulled a horrible 16.4. Should I back down the timing a bit? Will this help performance? Does thet much timing take off of the top end of the rpm power?
Thanks for any imput guys!
1983 Camaro Z28
Goodwrench 350ci V8, Edelbrock TES Headers, Flowmaster Catback, MSD 6al and Blaster 2 coil, Edelbrock Performer intake, Edelbrock Performer 600cfm carb. T5, 373 rear, Eibach springs, Cervin Vega speakers, Rock. Fos. Sub, Pioneer CD,
email-chris4421@hotmail.com
"I used to be a Mustang Guy! I didn't know the power of the dark side!!"
Old Jan 6, 2001 | 02:00 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Well, you've apparently learned first hand what I've been saying all along.
Advanced ignition timing 'feels' good to the seat of the pants, but the the engine will lay down on you once it stretches out and the internals head up from the combustion.
Assuming no mechanical problem exists, backing off on the timing will bring back the performance.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Jan 6, 2001 | 02:07 PM
chris83z28's Avatar
hmmm, that was my thoughts as well, I will try retarding it down some. Thanks!
1983 Camaro Z28
Old Jan 6, 2001 | 10:43 PM
Andy89RS's Avatar
If you can get in enough runs during a day at the track try different settings for each run. Start at factory or a few degrees advanced, make a pass, advance it some more, make another pass etc... At least that way you'll have real numbers to back up your SOTP feeling.
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Jan 7, 2001 | 09:49 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
As stated above, the best way would be to get time at the track and play with the timing a little to see what works better.
I have my +.020 400 in my truck running at 15 degrees base (35 total) and it loves it.
[This message has been edited by Engineboy (edited January 08, 2001).]
Old Jan 7, 2001 | 10:05 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Base timing should be set to achieve a total timing of 38 degrees. In order to do this, you will need to know how much advance is built into the PROM. Install a timing tape. Then with a timing light, rev the engine until total advance is achieved. Adjust your base timing until 38 degrees TOTAL timing is shown on the timing tape. This will insure optimum timing and maximum performance at WOT.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Jan 7, 2001 | 10:15 AM
82camaro's Avatar
Car: 82 camaro SC
Since you have a non computer carb, I'm assuming you have a non-computer distributer. If you have a computer dist. it's probably not giving you any advance. How much advance does your dist. give you? Total timing is going to be more important that your initial timing. You may need to get a recurve kit to recurve your timing curve. Also, the optimum timing varies from car to car. So, track testing is really the only method to find the optimum timing.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bamaboy0323
Sep 3, 2015 06:07 AM
cstrobel65
Aug 15, 2015 10:19 AM
bamaboy0323
Aug 15, 2015 07:20 AM
