What should I do with my charcoal cannister?
Old Dec 16, 2003 | 05:10 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I've removed the cat, smog pump, air diverter valve from my motor already. Do I need to keep the charcoal cannsiter? It's a 450+ hp efi motor which uses the same fuel rail/line assembly as a stealth ram. Plus I'm gonna add nitrous later. Do I need to keep the charcoal cannister?
I also plan on swapping to an ls1 plastic fuel tank. How will that play into things?
Old Dec 16, 2003 | 07:07 PM
blackbeauty's Avatar
Car: 1989 Trans Am
Engine: 1989 305 TPI
Transmission: 700-R4
Axle/Gears: 2.77 10 bolt
I removed the charcoal cannister from my car because the TVS purge valve had died and my car would run rough until it got warm. My car ran perfect when cold when I removed the charcoal system.
If you have to worry about emissions then removing the charcoal system could affect you, but having said that, if you were worried about such things you wouldn't have removed the cat and other stuff.
With my car, the line that fed into the charcoal cannister from the fuel tank was the only way for it to breathe, so blocking this off will be a bad idea as you'll be needing some sort of filter to go over the end. Alternatively, block the breather line, and get a breathable fuel cap.
I shouldn't think using a plastic fuel tank will alter things, but I don't know for 100% certain.
Old Dec 16, 2003 | 09:59 PM
MikeS's Avatar
I think I would cook a steak.
Why not keep it? Part of the function is to handle vapors from the tank. As far as I know, that function won't ever go away. Of course, we'll hear that there is no point in doing that from some.
Old Dec 17, 2003 | 06:10 AM
ede's Avatar
ede
yeah it's a vent/filter for the fuel tank.
Old Jan 17, 2005 | 02:51 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i recently removed my charcoal cannister to clean up the bay and install my new combo washer solution/coolant overflow box but what should i go with the gas vapor line? i plugged the vacuum lines but with this fuel line do i need to plug it as well or leave it open to vent into the atmosphere???
Old Jan 17, 2005 | 03:01 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
leave it open. rout it somewhere in the fender or where you want to have it. you can also put a breather on it so that no dirt or something comes in it.
nebu.
Old Jan 17, 2005 | 03:36 PM
12secformula's Avatar
Car: 94 Z-28
I also removed my canister. Can I just shorten the line, and put some sort of filter in the back by the tank? Is it necessary to keep the line at all, because the tank has another line that comes off the tank which has what looks like some sort of filter already.
Old Jan 17, 2005 | 06:01 PM
Marc 85Z28's Avatar
I put a length of hose to an EFI fuel filter on it to keep gas and fumes in, and debris out. Tucked it up under the car. And since I have no fumes even in the garage, I'd say it works.
Old Jan 17, 2005 | 09:13 PM
Car: 94 Z-28
An EFI filter? Is that like a normal fuel filter? I am just curious. Does it matter if its an actual fuel filter, or just a plain breather?
Old Jan 17, 2005 | 09:41 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
If you want to set it up like the pre-charcoal canister days(pre-1971) plug or remove the vapor line(plug gas tank port then) and install a vented gas cap.
Old Jan 17, 2005 | 10:27 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
i thought all gas caps were designed to vent?? but i guess ill just run some lines over under the fender.
Old Jan 18, 2005 | 05:45 PM
Marc 85Z28's Avatar
Install a vented gas cap? Good luck... I couldn't find one that fit.
I refer to your common inline filter found on most modern EFI systems as an EFI fuel filter. My car uses small paper element in the fuel inlet of the carb, as most factory carbs do. I used a fuel filter over a breather because I had one laying around.
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
TBRays98
Sep 6, 2015 05:05 PM
BurlyChev
Aug 16, 2015 09:08 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
