Lt4 cam with 416 heads? can it work?
Old Dec 20, 2003 | 03:04 AM
gunz4life2's Avatar
Car: '91 Firebird
Engine: 305 TBI
what needs to be done in order for my LO3 (305) to be able to handle the lt4 cam? What springs...RR's...retainers...locks...etc. Can I reuse my lifters and pushrods? Has anyone used this cam head combo before? Thanks for any help.
Old Dec 20, 2003 | 08:00 AM
ede's Avatar
ede
any time i got to a larger cam around or over .475 lift i like to install screw in studs and maybe cut the spring seats for larger springs. also a good time/idea to look at machining valve guide height. i also trash the stock springs, rotators, and retainers and go aftermarket. buy springs to match the cam and i would use gm springs, look at comp, lunati, or crane. personally lunati is all i've used in a very long time, just bought a new lunati cam, lifter, spring set a week or so ago for my current project engine.
Old Dec 20, 2003 | 12:48 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Remember that a lt4 camshaft is .480 lift with 1.6 rockers. If your using stock rocker arms your lift won't be as high. I have a lt4 camshaft with my stock lo5 heads. I didn't change anything and its working fine. I plan on some modded vortechs someday.
MustangBeater20
Oct 29, 2022 09:20 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
