air pump
Old Dec 20, 2003 | 10:44 PM
kamaroirock's Avatar
Car: 02 z28, 03 wrangler sport
Engine: ls1, 4.0L
Transmission: t56, 4speed auto
air pump
my air pump is making some odd noises and i want to replace it before it locks up on me. i wanted to know how hard it is to replace one and how much it would cost to get a new one for my 305 TBI. thanks
Old Dec 20, 2003 | 11:00 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
If I could figure out how to reroute my belt, I'd take mine off and give it to you.
Old Dec 20, 2003 | 11:16 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Here you go.
Old Dec 24, 2003 | 12:55 AM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
mine went out...
half way thru a road trip,almost thought it was the water pump making the sualling noise,now seems the air pump bearing on the pulley has really the problem,currently the car has no cat so the belt reroute is the way to go,Thanx all!!
Old Dec 24, 2003 | 01:21 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
Re: air pump
what kind of noises? gurgling/burbly sounds are annoying but normal.
Old Dec 24, 2003 | 01:48 PM
ede's Avatar
ede
unless you need it for e chack most people remove them
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
