wont turn for about 8 tries then it does whats the problem?
Old Dec 21, 2003 | 02:41 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Transmission: TH-700R4
Other then the nice puddle of coolant on my passenger side floor , sometimes when i try to start the car up it wont turn over for a bunch of tries, then all of a sudden it does. I damaged my starter wires but got them replaced by a mechanic (cuz i didnt know what the problem was) and i just wana know if thats the problem thanx
SSBO
Old Dec 22, 2003 | 05:31 AM
ede's Avatar
ede
bad connection or ground, maybe bad key cylinder, park or clutch safety switch
Old Dec 22, 2003 | 08:40 AM
HeavyBreathinRS's Avatar
Car: 1990 RS
...or starter or starter solenoid....the starter was the problem on mine...exact same symptoms.
Old Dec 22, 2003 | 08:51 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Get the leak fixed.
Can you guess where the starter is???
*Ding ding ding*
That's right... under the heater core.
Antifreeze and starter solenoids don't like each other to much, and the antifreeze usually wins.
Old Dec 22, 2003 | 10:36 AM
KC10Chief's Avatar
I agree. The starter is most likely the culprit. I've had this problem on my GTA, my SSEi Bonneville ($400 starter for an SSEi), and a Pontiac 6000 I had years ago. All did the same thing you described. It was even worse when the engine was hot. Matt
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
