Pertaining to my other post, for a SuperRam, what is the best cam, for the HSR, what
Old Dec 22, 2003 | 10:57 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
is the best cam???
I had picked out the XR276HR cam (224/230/.503"/.510"/112LSA).
But I am camshaft challenged!!!!!
If I keep the SuperRam, what would make for a great cam? The LPE219 was suggested.
If I switch to the HSR (Holley Stealth Ram), then what would be a great choice for the cam??
The engine is 395 cu.in. with AFR190 heads and I will be tuning on the stock GM EFI system. The car is intended as a street/ strip car, and I have an 700R4 tranny.
Old Dec 23, 2003 | 10:26 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hey Buddy, keep it one post..lol.
Someone here has started a "Holley Stealth Ram" website, I don't have the link, but you may find it by default like www.stealthram.com or similar, or post up and ask what the link is.
IIRC, different combos and such were listed.
Also, do a search for user name "ski dwn it" or similar, he has a 406 in a Vette and is/was knocking on 10's with the SuperRam and MAF setup.
Good luck.
EDIT:
Well I'll be...www.stealthram.com is the correct link
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
355tpipickup
Aug 22, 2015 06:06 PM
355tpipickup
Aug 13, 2015 07:35 AM
Fronzizzle
Aug 9, 2015 01:15 PM
