mystery oil leak
Old Dec 26, 2003 | 11:27 PM
ponykiller's Avatar
Car: 89 camaro w/t-tops
Engine: lo3
mystery oil leak
I've got a pool of oil on the intake manifold by the thermostat and cant figure the sob out.The common sense answer would be the valve covers but theres no "flow" marks. Its just...there.I wipe it off and I returns.Theres no cracks in the intake either.
Old Dec 27, 2003 | 02:24 AM
demonchild's Avatar
PVC
Old Dec 27, 2003 | 07:30 AM
owned's Avatar
There are several intake manifold bolts that are "wet". If they are loose, or if they were not installed with a little rtv on the threads, they can leak. This is what I would guess the issue is.
Old Dec 27, 2003 | 07:50 AM
EvilCartman's Avatar
Car: '82 Z28
I had that happen on the 305. 2nd intake bolt back from the front of the engine on the passenger side. I just used some thread sealer and all was fine.
Old Dec 27, 2003 | 10:45 AM
ponykiller's Avatar
Engine: lo3
Thanks guys..I'll check the intake bolts and pvc.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
