LG4 Guys
Old Jan 8, 2001 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
LG4 Guys
I'd appreciate it very much if you'd please list your mods.
JamesC
Dual snorkel air box and K/N filter, AH metering rods with G hanger, high-flow cat and catback system, alum drive shaft, B&M Ripper, 3.23 with discs and limited slip, Mobile 1, Spohn panhard and LCAs.
[This message has been edited by JamesC (edited January 08, 2001).]
Old Jan 8, 2001 | 07:32 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Here's mine.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Jan 8, 2001 | 09:32 AM
86SCBNJ's Avatar
here's mine...
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Susension Technique Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with Toyo 245's. For autocross, 16" IROC's w/bfg R1's... Need more speed.....
Old Jan 8, 2001 | 10:20 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
My mods are in my signature. I'm still using the orginal block and pistons from my LG4 that have about 100K miles on them. The heads are orginal too but have had a lot of work done to them. I've had a best 1/4 mile run of 13.4 at 101mph so far. So an LG4 can run decent times if you match your combination up well.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Jan 8, 2001 | 10:55 AM
Dana'86_305's Avatar
here's mine
86 Camaro
LG4, Tuned Q-Jet
Edlebrock Performer Intake, Edlebrock Open Element,High Flow Cat,Dynomax Catback,B&M Megashifter, 180* TSAT, 3.42s, 800 Watt System, !EGR
Old Jan 8, 2001 | 11:29 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Here's mine-
carb tuning (minor, will be switching to a g hanger and ah rods myself)
1 inch poly carb spacer- MUST DO - made a big difference for 30 bucks...
3 inch high flow cat and slp cat back to open pipes (yes it is loud and sets off more car alarms, but i LIkE it!!)
ignition advance to 8*-10*
(soon to come- fiberglass cowl hood, headers, new heads, possibly ported, and a cam and performaer intake, gears- 342 posi disc sittin in my garage)
Steve-o
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat.
Current Plans: 342 posi disk 10 bolt rear, coming in late december, in february or april, level 10 tranny, new convertor, june- lowering springs, possibly torq thrust II chrome wheels, and new 245 stickies up front, 255's out back, the cowl hood will be installed and painted, new cold air induction, mid summer, hoping to have enough money to scrape together a 350 hp 350... gonna keep things fairly mild.
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
Old Jan 8, 2001 | 12:44 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
fb305svs, how did your carb spacer work out? have enough underhood clearance? ive yet to start work on my lg4 iroc, but once i do my first mods are gonna be a slightly bigger carb and spacer, but was worried about clearance..
aside from that mods to be done
head job, cam, performer intake, carb, cooler stat, catback kit, etc.. i dont know about headers yet.. possibly, yet doubtfully..
Old Jan 8, 2001 | 08:42 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Mine are in the sig, oh wait, I guess I don't count any more. Hey, its still the LG4 block, heads, and exhaust manifolds!!!
This was the best mod I have done to my LG4!!
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited January 08, 2001).]
Old Jan 8, 2001 | 08:53 PM
SGT SWEETPANTS's Avatar
Nothing very exciting, but parts are waiting for warm weather and dry roads. (intake, exhaust, MSD)
'86 IROC-Z, 305 LG-4, T-5, T-Tops, 50k Original Miles, K&N Air Filter, Jet chip, KYB Shocks/Struts, Centerforce Dual Friction, B&M Ripper Shifter
Old Jan 8, 2001 | 10:15 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Getting rid of that stupid clutch fan made a difference off the line (Dual electric). Regular maintanence has been a big factor, but more in the fact that it's still running at 199,500 miles. Timing reset to about 10 degrees.
The best mod that I will be doing to it in the future, is replacing it with my 350 (basically a ZZ430).
That looks sweet in there GMTECH. Nice airbox!
Good luck with whatever you do!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
ASE Certified Master Tech
Starting to look like the Kicker poster child!
Old Jan 8, 2001 | 10:32 PM
Bort62's Avatar
Well, Here is hwat i got.
Mechanical Qjet ( unknown CFM, but LARGE ) using the stock E4ME Hangers.
Vaccum advance Distributor
3" Exhuast
edlebrock open element drop base air cleaner (14")
MSD superconductors
No Emissions what so ever.
No AC
No Power steering ( not by choice )
Oh yeah, Timed 14* btdc, If You can trust a Dampner with 150k on it, Its timed to Just before it wants to ping, However.
And yeah, it scoots.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
[This message has been edited by Bort62 (edited January 08, 2001).]
Old Jan 8, 2001 | 10:39 PM
jrob350's Avatar
The best mod for the slacking lg4 is to replace it with some more cubes like I did mine with a 383 stroker 330+hp 440+lbs-torque
Old Jan 8, 2001 | 11:30 PM
Mike92's Avatar
I been needing to try on my FlameSuit on again it's been a while. Dual snorkel intake, headers, performer intake reworked Q-jet and gears should get you low 15's high 14's at around 90-93mph if your engine is in good shape. A performer cam would lower that by half a second at least and add 3-5mph trap speed. 204-214.
Old Jan 9, 2001 | 09:12 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
K&N open air 14" element, double roller timing chain, no smog pump, carb tuning, shift kit, no cat, lead foot.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Jan 10, 2001 | 12:06 AM
crazygearhead's Avatar
i used to have an LG4. I had a 14" K&N filter, Holley 650 carb, 1" spacer, edelbrock performer intake, plugs and wires, as well as a valve job, i also removed the A/C and the air pump, no cat. I'll tell you one thing though, the holley 650 had some great throttle response. it never bogged and always wanted to go. I reccomend the smaller carb actually. Just from personal experience.
If it breaks, it wasn't good enough anyway.
Old Jan 10, 2001 | 11:50 PM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
removed lg4... installed L69... slp catback... installed 700r4... much more fun...
Old Jan 11, 2001 | 07:15 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Pete's Place
HiOutput.comTech Page
<IMG SRC="http://www.hioutput.com/pics/SC.gif" TITLE="Pete's 83 SC">
My 83 SC...(originally V6) 203,700 mile LG4/5-speed from an 84 Z28, 3.42 one-tire-fryer, T-tops, PW, PH, boxed LCA's, Hedman Hedders and y-pipe, Dynomax cat-back, .420" lift cam, custom air induction .....best ET is 14.935@94.14 with a 2.36 60-ft time</P>
RazorN8
Jan 7, 2022 11:44 AM
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
