aircleaner ?
Old Jan 10, 2001 | 09:59 AM
black84ta's Avatar
aircleaner ?
whats better open element or ho dual snorkel?
Old Jan 10, 2001 | 10:54 AM
Neo's Avatar
Neo
You will get just opions I do not belive there is a true better one. I have open air and love. It but if you want you can do both.
Mike Kenny
Current: 1991 RS 305 TBI
Past: 1990 RS 305 TBI (A woman forgot what red lights are for)
Current: mostly stock - newer 305 w/ 12,000 on it
Eclipse speakers all around w/ 10" tube powered by a Alpine V12 in back
K&N filter w/XStream flow lid - It is sweet!!
Future: 2" Cowl hood
Old Jan 10, 2001 | 01:09 PM
85berlinetta's Avatar
I have an edelbrock open element air cleaner (the triangle one). I love it. Noticed a big difference from stock.
Old Jan 10, 2001 | 02:16 PM
84TransAm's Avatar
Watch out for those open Fre-Flo that u can get for like $20. True they flow more, but when the engine sucks in that much air it will take the foam with it in chunks. I would return mine if i could find the receipt....
--Steve S-- 84 Trans Am 305 (cough)LG4(cough), 5 speed, Flowmaster 80 series, otherwise an emissions restricted slow 150 hp(chilton rating) 240 torquer that needs RELEASE!!!!
P.S. Daily Driver
Old Jan 10, 2001 | 02:40 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have a dual snorkel with a K/N filter. It's first rate.
JamesC
Old Jan 10, 2001 | 04:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IMHO the dual snorkel is the way to go. The restriction is negligible, and you get cold air instead of hot underhood air. THe HO setup should be worth about 5 HP or more over an open element for that reason. I'm still running my HO one on my 400, it dyno'd 283 HP & 373 ft/lbs at the wheels with the air cleaner installed and operating, so it will definitely do enough air for a 305.
Old Jan 10, 2001 | 05:08 PM
CamaroMike's Avatar
There was an article written on the HO Camaro conversion with the ZZ4 that did a test with the dual snorkel air cleaner. By just taking the lid off of the dual snorkel air cleaner the car picked up almost 5 tenths in the quarter mile. The stock dual snorkel is very restrictive compared to an open element.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 10, 2001 | 05:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Wow... I do have mine on a 1" spacer on top of the carb, I forgot to mention that, it made a significant difference. Couldn't say if it was .5 sec though, that's HUGE!!
BTW this is the primary problem with drop-base air cleaners. It doesn't matter how tall the filter medium is if all the air has to pass through what is basically a slit because the lid is so close to the top of the carb.
Old Jan 10, 2001 | 10:20 PM
84FTA's Avatar
If you have the functional 'Ram-air' option on your T/A I'd keep the dual snorkel. Lots of people have opted it out but I'm going to attempt to hook the ram-air up to a drop base air-cleaner on my Holley and possibly just block off the rest of the aircleaner (play with it and see what works). I've always liked the functional power buldge hood, kind of cool how they thought it through with the 140 deg. metal temp switch inline with the oil pressure switch, and vaccum switch...don't know how it will react with the choke heater being disconnect though.
Anyway, you can test and try. Air cleaners are $20 from Summit and if it does't do anything scrap it which isn't as much as a loss as a $60 air foil
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Jan 11, 2001 | 08:14 AM
MEANGREEN's Avatar
I would sort of base it around what you have:
If you have a pretty much stock 305 and a stock hood, I'd go with a K&N, Dual snorkel setup, and K&N Stubstack. If you need extra flow, turn the top of the air cleaner cap upside down, it'll give you a LITTLE more flow.
If you have or can get a cowl induction hood, I'd go with a 4" cleaner, 1" carb spacer, stubstack, K&N filter. The open element will work fine without the cowl hood, but you'll pull MUCH more cool air with either a cowl hood or raise the rear of the hood (which isn't much to look at, but is effective). Hope this helps
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
(Prospective purchase)
Old Jan 11, 2001 | 07:24 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Here's a setup you may be interested in if you have the 'turbo' style hood... http://www.angelfire.com/nb/thirdgen/air.htm
Pete
Pete's Place
HiOutput Virtual Racing Team
MotorCityMuscle
Carburetors
Sep 23, 2001 11:07 PM
Dirtybird355
Carburetors
Aug 26, 2001 03:20 PM
86 sports coupe
Aug 7, 2001 09:58 PM
TAdan
Jun 14, 2001 09:51 PM
MuchoCamaros
Feb 4, 2001 12:40 AM
