Checking lifters?
Old Dec 30, 2003 | 05:35 AM
ede's Avatar
ede
Checking lifters?
what is the length required for a set for a SBC, BBC? thanks
Old Dec 30, 2003 | 06:38 AM
ede's Avatar
ede
length and diameter for a flat and hydrolic roller dummy pair of lifters. i knew what i meant to say but wasn't very clear.
Old Dec 30, 2003 | 06:40 AM
Pat Hall's Avatar
The only thing I can remember right now is the hydraulic roller setup requires a pushrod that's .100 longer than the flat tappet.
Old Dec 30, 2003 | 08:13 AM
ede's Avatar
ede
push rod length doesn't matter much for this, but the roller lifters i beleive take a shorter push rod. i'd have to look in a catalog but i'm thinking stock length SBC push rods for a flat cam are 7.8 and stock length for a hydrolic roller are 7.3
Old Dec 30, 2003 | 02:29 PM
ede's Avatar
ede
i thought for sure rb, vader, or five7 would know the answer off the top of their head. guess i'll have to look when i get home tonite.
Old Dec 30, 2003 | 03:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I don't know the lifter height offhand... SBC push rods are approx 7.200" for a factory roller and 7.800" for a flat tappet.
http://www.compcams.com/catalog/268.html
SBC and BBC lifters are the same. .842" dia.
Old Dec 30, 2003 | 03:44 PM
ede's Avatar
ede
i know it was a pretty obscure question. i didn't have much to do today and thought i'd make a set if someone could of gave me the specs. i know i have a set of flat hydrolics at home i can check and make a set tomorrow.
Old Dec 30, 2003 | 04:24 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
post the results if u dont mind, i would like to know since u got me thinking.
Old Dec 30, 2003 | 06:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I don't have my calipers handy right now (too cold to go out and get them) but I know that Comp has the spec's listed on thier site...I compared diameter and heigth of a set of linkbar rollers I had to thier specs listed.
Old Dec 31, 2003 | 04:55 AM
ede's Avatar
ede
ok i checked a new set of flat hydrolic lifters i got from lunati, not that lunati makes lifters. without my glasses on ( i'm getting old) it looks like .842 diameter and 1.997 length and the bottom of the push rod cup is .300 below the edge of the lifter and i'd add .050 to the .300 to allow for compression of the plunger. so next chance i get i'll make a set. now if someone can come up with specs for a hydrolic roller because only ones i have are inside of engines.
Old Jan 5, 2004 | 05:40 AM
ede's Avatar
ede
for any one that digs this up on a search i found a old roller lifter. overall length is 2.6 with the same .3 recess for the push rod.
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
z28guy134
Sep 1, 2015 11:50 PM
