Best Head Gasket Set
Old Dec 30, 2003 | 11:50 PM
sorch60's Avatar
Does anyone have an opinion on what the best head gasket set out there is? Any input would be appreciated.
Old Dec 31, 2003 | 01:14 AM
Morley's Avatar
Depends on the heads you are going to use them on, but Felpro brand is about the best.
Old Dec 31, 2003 | 03:23 AM
ronterry's Avatar
Car: '94 Corvette
I use Felpro 1010 on my aluminium heads.
Felpro 1014 for iron heads.
There both .039 thickness.
Ron
Old Dec 31, 2003 | 04:40 AM
ede's Avatar
ede
fel pro gaskets is all i use if i'm buying them. i build a few engines for a guy that buys no name gaskets from a engine rebuilder supply and he's never had a problem with them, but he doesn't keep anything very long either.
Old Dec 31, 2003 | 05:10 AM
ronterry's Avatar
Car: '94 Corvette
I realy can see why 'ede' cause these Felpro's are like 35 a piece.
If I were pumping out street engines, I would probably use Detroit Gaskets or what ever, for a third of the cost.
Last Checked the Felpro 1010's are 36.99 each & the 1014 run 31.99 each ...and 'sorch60' what I mean by each is one gasket, not a set.
I'll be frank also, I never had a problem with Detroit's, Mr. Gasket or the ones that come with felpro engine kits.
These 1010/14, I guess are considered a performance head gasket.
Ron
Old Dec 31, 2003 | 05:46 AM
ede's Avatar
ede
i love the fel pro one piece oil pan gaskets to, again they're around 35-40 dollars. sucks you can't buy them in a gasket set and have to buy a 4 piece gasket with the set and then buy the one piece as well to get it. i don't know of anyone else that makes one piece oil pan gaskets.
Old Dec 31, 2003 | 04:05 PM
sorch60's Avatar
Trick Flow sells gasket sets, does anyone know anything about those?
Old Dec 31, 2003 | 04:12 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
I've used "Cortecco" brand gaskets before, in fact , thats what is in my blazer right now, If you never heard of them, they are a marine performance gasket, very good quality, above the standard replacement felpros, possibly on par with the perfomance felpro stuff
felpro stuff is good too
I get the Corteco stuff from my engine builder
Old Dec 31, 2003 | 04:43 PM
Morley's Avatar
I think they are made by Felpro, just re-branded for Trick Flow.
Old Dec 31, 2003 | 05:43 PM
sorch60's Avatar
That's interesting, if this is true the trick flow version is sold for SBC up to '86 which is good.
Old Jan 1, 2004 | 07:27 AM
ede's Avatar
ede
you can always go with factory pieces too. often cheaper than fel pro and you know they're OEM spec.
Old Jan 1, 2004 | 10:27 AM
Morley's Avatar
Last time I got head gaskets from the dealership they were $5-$10 more than Felpro's through Summit. The intake gaskets, however, are a few $ cheaper at Chevy...go figure.
Old Jan 1, 2004 | 11:54 AM
Slick86's Avatar
Car: Pontica F-bird
Engine: 355
Transmission: 700-R4
If you need more than head gaskets, the entire engine gasket set from fel pro is the same price as two head gaskets and it comes with those.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
