GM crank pully that can hold 2 surp belts?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
anyone know of a GM crank pully that can hold 2 surp belts? and what did it come in?
i really would like to run this blower off a 2nd belt all its own instead of sharing it with the rest of the accessories... is there a GM truck or car or somthing that has two pullys close to each other...
im hoping theres one that uses a one piece two belt pulley like they made with V belts... because theres not alot of room between the crank and the sway bar... and there will be even less room when i upgrade my sway bars later on...
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
well, my 2000 grand prix gtp has a serp belt driving the accessories, and a second one driving my supercharger. i have no clue if they would interchange with a SBC, but it might be worth it to go to some junkyards and grab one to find out. 97-03 gtp's should have it. hope this helps
