274h cam with an L98..too much?
Old Jan 7, 2004 | 03:59 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
Hey guys, I was looking at the description of the 274h Crane Energizer Cam and it seems to be what I'm looking for...rough idle, not too high of an RPM range and it's a street/strip cam. Is it too much for an L98 though? It’s a manual L98...the only mods I’ve done to it is converted it to carb. Edelbrock performer intake, edelbrock 4bbl 650cfm carburetor, and a blue Holley electric fuel pump. I was planning on maybe porting the heads and defiantly getting some headers, and maybe a bigger carburetor (700 - 750cfm maybe? I don’t want to go too big) what do you guess think/suggest? Would I have to upgrade any of the valve train if I get this cam? Or should I upgrade the valve train?
Here are the specs of the cam:
Application
Rough idle, moderate performance usage, good low and mid-range torque and HP, mild bracket racing, auto trans w/2500+ converter, 2600-3000 cruise RPM, 8.75 to 10.0 compression ratio advised. Basic RPM 2200-5200
Cam Specifications
Series & Grind Number - Energizer 274 H06
Degrees Duration @ .050 Int./Exh. - 218/218
Degrees Advertised Duration Int./Exh. - 274/274
Degree Lobe Separation - 106
Gross Lift Int./Exh. - .450/.450
Old Jan 8, 2004 | 08:00 PM
84zeddd's Avatar
I think all L98`s are roller cammed and if the cam you picked is the one I am thinking of it is a flat tappet cam.
Old Jan 8, 2004 | 10:40 PM
Engine: carbed L98
are they all roller cams? and what would be a comparable roller cam that is similar to the 274H?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
