cam selection 406" superram setup
Old Jan 8, 2004 | 02:48 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
need help with cam selection on my new engine.
Currently I have tpis zz9 camshaft but it seem a bit small for a 406cui. Maybe getting a single pattern cam?
406"
9.2 comp
JEGS 197 cc heads
Superram intake
TH700 act 2500rpm
9 psi procharger
Wont rev beyond 5800 rpm probably will stay at 5500 rpm.
Street driven, must pass emission.
thx/N.
Old Jan 8, 2004 | 05:40 PM
GroundPoundinZ's Avatar
You may want to look into the ZZ-409 cam from TPIS. It is quite a bit more aggressive than your ZZ-9 cam, and intended primarily for larger cubic inch small blocks such as yours. It will make roughly 40 more HP @ 5800 than the ZZ-9 cam with no loss in lower end torque. These numbers are based on a naturally aspirated 406. The cam will make peak HP in the 5800-6000 RPM range.
In Illinois we are not required to pass an emmision test so I am no expert on emmission questions. You will have to try to get that information from someone that knows more about it than me.
It is a single pattern cam with these specs:
.525 lift w/ 1.5's
226 Duration @ .050"
288 Adv. Duration
112 L/S
Hope this helps.
Old Jan 9, 2004 | 12:24 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
ZZ-409 Hyd Roller:
Adv. duration 287/287, duration @.050 226/226, Lift .520/.520. 112 LSA.
ZZ-9X Hyd Roller:
Duration @.050 225/240, Lift .525/.558 on a 112 LSA.
CC NX276HR
276/288 224/236 @0.050 0.502/0.520
CC XR276HR
276/282 224/230 @0.050 0.502/0.510
Pros/cons of these to cams for my appl.?
Will teh pass emission?
Superram is supposed to like sigle patter cams but with a blower a dual patter is recommended......
Street Lethal
Apr 30, 2019 12:14 PM
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
