How do you store your camshafts?
Old Jan 8, 2004 | 09:33 PM
smithtc's Avatar
I have two cams (LT4 Hot), and a 74219 LPE cam that I am not going to use anytime soon, but want to maintain their "usability".
Can I just spray some gunk on them, and throw them in a box? Siran wrap them too I reckon? Will that be enough?
Old Jan 8, 2004 | 10:34 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I would clean the cams and put some lithium grease on all the lobes/bearings then enclose it in a plastic bag and store it away where it will not be tampered with and avoid moisture and water/condensation.
Dave
Old Jan 8, 2004 | 11:42 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I'd do what was already mentioned and get some 2" PVC pipe and slide em in there for protection from dings.
I live where it's humid and I've learned to treat my stored engine parts like a gun, take it out every so often and oil it.
Old Jan 9, 2004 | 01:57 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
When you seal them in a plastic bag or container, use some desiccant to absorb the moisture that’s in the air.
Old Jan 9, 2004 | 08:42 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
a nice thick coating of oil, or like someone suggested, spray on grease...... mostly you want somthing that wont slide off over time...
if you do use somthing like regular motor oil, wrapp it tightly in clear wrap so that the oil stays on it...
that PCV pipe tube thing is a good idea too.
Old Jan 9, 2004 | 09:43 AM
ede's Avatar
ede
pvc, cap one end install cam fill with oil glue cap on other end
Old Jan 9, 2004 | 09:48 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Well, if ede's suggestion doesn't keep it free of rust then I don't know what WILL.
Old Jan 9, 2004 | 12:33 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Hose 'em down with WD-40 & seal it in a plastic bag. Stored my original L98 cam like that for 3 years, it was good as new when I took it out.
Old Jan 9, 2004 | 01:26 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Just send me the LPE219 and I'll store it in my engine for you...save you all the hassle of getting oily, etc....
RedLeader289
May 28, 2019 01:47 PM
Briandrex
Oct 5, 2015 06:20 AM
meeklay812
Oct 1, 2015 03:46 PM
ironbmt
Sep 27, 2015 06:00 AM
blackandblue02
Sep 10, 2015 08:19 PM
