for those that have never seen ....
Old Jan 9, 2004 | 07:53 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
what a small base circle cam looks like, well here you go. aren't the lobes cute????
Old Jan 9, 2004 | 10:16 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
This is one reason you would need longer push rods.
Old Jan 9, 2004 | 10:25 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Hey, you can run a lot of stroke with one of those!!!
Old Jan 9, 2004 | 11:37 PM
89rs/sc's Avatar
Car: 89 rs
Engine: 305 supercharged
Transmission: th 700
?????? stroke
Old Jan 9, 2004 | 11:41 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
He means a lot of stroke on the crank. Small Bases are normally seen in stroker motors where the smaller lobes are need'd for clearance issues.
Looks good mrr23! Maybe I could get my custom ordered if the shop would ever get off their butts and do my machine work. They've had my stuff for almost 6 months now!
Old Jan 11, 2004 | 08:12 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
those are cute little buggers
would much does it cost to adopt one of those things
Old Jan 11, 2004 | 08:44 AM
mrr23's Avatar
Engine: 360 HSR
about $375
Old Jan 11, 2004 | 12:40 PM
Engine: 383 SBC
Yep, Comp Cams quoted me around 300 bucks for a custom solid roller acouple months back. Then you're looking to spend 350 to 400 for the comp cams solid rollers for small bases (891-16).
ULTM8Z
Sep 16, 2015 09:15 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
Roshambo
Aug 24, 2001 08:48 PM
CrazyHawaiian
Car Audio
Aug 6, 2001 04:16 PM
IROC315
May 15, 2001 10:34 AM
