Porting my heads myself....worth it????
Old Jan 16, 2001 | 12:16 PM
CamaroX84's Avatar
I am rebuilding an 89 350 TPI motor, which is completely stock. I plan on porting the intake, installing the LT4 HOT Cam, getting headers, high-flow cat, Hooker Cat-Back, and an AFPR. My question is, since I have never ported a set of heads before, would you recommend that I do it myself? If I do, what do I need to be careful about? Also, anyone have any documents on head porting? ANY help would be much appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
Old Jan 16, 2001 | 12:34 PM
Box of Rocks's Avatar
X84,
Porting the heads will help, but it will help more if you port-match your intake to the head too.
Go to www.sa-motorsports.com/diyport.htm
That is Standard Abrasives' website, and it will guide you thru a basic bowl port job and port-match.
You can expect 20-25 HP from the head and manifold work.
Good luck !
BOR
Old Jan 16, 2001 | 10:04 PM
CamaroX84's Avatar
It doesn't look too hard to do, but would you recommend that I myself, who has never ported heads before, do it with only the help of that document? Did anybody else use the SA document? If so, how'd they turn out? Thanks.
Old Jan 16, 2001 | 11:14 PM
Vader's Avatar
X84,
Check the other posts on head porting in the active topics and the archives. It's not difficult to do correctly, but is time consuming.
It's also not difficult to do wrong. If you've never done it before, I would suggest calling around to some of the local repair shops and asking if they have any old junk heads that were removed. If you get a scrap head to practice you grinding, you'll get an idea of what's involved. You'll have a little time to study the castings, and can even cut it in half to find the water passages and see what areas to avoid.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 16, 2001 | 11:33 PM
Bort62's Avatar
Since you Mention the LT4 HOT cam, Your prolly Going to Want to get the heads Machined to accept Bigger springs, screw in studs, ECT...
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
beastin91rs
Oct 9, 2015 07:38 AM
italiano67
Aug 31, 2015 06:04 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
