Remove Carbon/Oil Buildup
Old Jan 11, 2004 | 03:27 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
What different ways have people removed the carbon/oil build up in the intakes while their off the engine?
I have tryed the engine rebuild shop, got some off.
I have sprayed with gastrol super clean, helped a bit. Doesnt help where I cant get an old toothbrush.
Carb cleaner works, but takes a butt load.
Any other ways?
Old Jan 11, 2004 | 03:46 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
To get it pretty much completely cleaned you could have it hot-tanked by a machine shop. That should clean EVERYthing off it. If you wanna do it yourself, I found that "Easy-Off Oven Cleaner" (found in most grocery stores) does some insane cleaning ...It'll break down crud and even paint with ease. Apply it (or any other kinda engine degreaser stuff you can find) and let it sit for about 15 minutes then power-wash it at a car wash ...could clean up pretty good.
Old Jan 11, 2004 | 03:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Permatex 4MA Gasket Remover, followed by the quarter car wash. It will strip it to bare metal.... paint, gasket remains, everything.
Old Jan 11, 2004 | 08:30 PM
Dale's Avatar
Engine: 350 S-TPI
88iroc, I have taken it to a machine shop. Not sure what they did, but the final product wasnt what I wanted.
Sounds like I will have to try oven cleaner, or that gasket remover.
Anyone have other ideas/solutions?
Old Jan 11, 2004 | 11:12 PM
Vader's Avatar
Be very careful about using any caustic cleaners on aluminum (your intake, etc.). Caustic has a realy affinity for aliminum molecules and will continue to dissolve the metal even after rinsing. It needs to be neutralized with a mild acid, then triple rinsed, and will still often promote severe oxidation (blackening) of the aluminum after use.
Old Jan 12, 2004 | 05:39 AM
ede's Avatar
ede
dish washer works good for cleaning parts if you can send the wife to the mall for a hour or two. i sort of preclean everything before it goes in the dish washer.
Old Jan 12, 2004 | 09:15 AM
Dale's Avatar
Engine: 350 S-TPI
vader, which ones listed are caustic?
the over cleaner, or the gasket remover?
Dishwasher one is not an option, but thanks for future reference.
Old Jan 12, 2004 | 09:30 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Oven cleaner and gasket remover are both caustic.
That's why you do it at the quarter car wash: so you can wash every trace of the chemical off of the parts.
Old Jan 12, 2004 | 09:51 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
One other hint, After cleaning the part in the dishwasher, make sure you do two empty loads, to make sure there is no residue in there. Don't ask me how i know . the things we do for our cars....
Old Jan 12, 2004 | 11:47 AM
Morley's Avatar
I used Valvoline Syn power carb & Throttle body cleaner, it will eat carbon like water washing away mud.
Old Jan 12, 2004 | 05:00 PM
Vader's Avatar
C'mon, Ed... You're not telling the whole story...
Old Jan 12, 2004 | 05:38 PM
305Tiger's Avatar
Car: 1987 Trans Am
Engine: LG4 305 w/emissions & A/C delete
Transmission: "...check!"
Axle/Gears: it's crap...they're stock!
lol...
like the whole dishwasher one...hehehe! My fiancee's uncle has an 81 camaro and one night we watched their kids....and hotd@mm....went to the kitchen and his headers were in the sink! hehe!
-G
Old Jan 12, 2004 | 06:25 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I can vouch that mothers get really mad when you put your lower tpi intake into the dish washer and set it to "Pots and Pans". I got yell'd at for a long time, course dad thought it was a good idea after hearing what I did.
Old Jan 12, 2004 | 10:13 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
what about plain jane gasoline? I used it on one of my heads after going through a can of tb cleaner and still having a ton of grease left on the head.Cheaper too. just smells bad!!!
Old Jan 13, 2004 | 01:46 AM
25THRSS's Avatar
sand blast the thing
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
