Throttle Body Question
Old Jan 11, 2004 | 09:47 PM
GroundPoundinZ's Avatar
Does anyone know how much HP the stock 48mm throttle body will support? The reason I'm asking is because I'm still running the 48mm TB on my fairly warm 350, and am wondering what I'm leaving on the table. Last time at my local 1/8 mile track, I was running consistent 8.1's N/A. :rockon:
Old Jan 11, 2004 | 10:21 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I don't know.
However, I doubt it is holding you back very much. It is of course impractical to buy a bigger TB and install it and test it. However, it is NOT impractical to buy a TB airfoil to see if the increased flow yields noticeable gains. I would pop in a TB foil (many on ebay) and see - if you notice a gain at the track, then that is very telling.
Old Jan 11, 2004 | 10:59 PM
Vader's Avatar
At least 510 HP. The GMPP RamJet 502 makes 510 HP with a stock dual 48mm bore throttle body (from an LT1). It might do better with a larger one, but that's the HP rating.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
