polyurithane motor mounts??
Old Jan 11, 2004 | 11:56 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I have an 89 bird and I wunt to put some plyurathane motor mounts in it be4 i put the motor in, Now I am confused as to witch ones I need, All I can find is wut looks liek the inside of the mount. Now do I buy this and rip the old one out and just slide this one in or wut?? thanks
http://www.jegs.com/cgi-bin/ncommerc...74&prmenbr=361
IS it this part #355-3-1116G
Do I need 3 or 4 bolt?? thanks guys
Old Jan 12, 2004 | 12:43 AM
MdFormula350's Avatar
heres another option.
http://www.spohn.net/product.cfm?productid=1363
Old Jan 12, 2004 | 06:06 AM
ede's Avatar
ede
most if not all of the mounts fit inside the 2 metal shells. there have been a few people on here report problems with ES poly mounts along with the poly trans mount making the engine sit higher by about 1/2"
Old Jan 12, 2004 | 08:38 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
3rd gens use 4-bolt engine mounts. You want the -1116G (black) or -1116R (red).
You are buying just the isolator, you still use the existing steel clamshell mounts.
Old Jan 12, 2004 | 03:46 PM
Car: 89 Formula
Engine: Carbed 5.7
Ok so what you are saying is that the actual mount that bolts to the k-member stays bolted to the car and u just rip out the guts and put the polyurathane inserts in?? also i don;t see how it could make it sit a half inch higher if its still inside that stock shell cause my stock ones are about at the top of it anyways?? thanks for clearin any of this up guys
Old Jan 12, 2004 | 05:57 PM
305Tiger's Avatar
Car: 1987 Trans Am
Engine: LG4 305 w/emissions & A/C delete
Transmission: "...check!"
Axle/Gears: it's crap...they're stock!
thanks!
...just cleared up the same subject I had just run into about two weeks ago!
-G
Old Jan 12, 2004 | 07:10 PM
ckeene502's Avatar
you will have to take off the mounts and drill out where they are "pressed together" then put in the new goodies!!!
keene
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
