Car Still Won't Start
Old Jan 17, 2001 | 10:10 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The spark plugs appear to be fine, we have taken them out and they create a spark , the timing is perfect ( already taken a timing light to it), I am having a mechanic come over tomorrow to readjust the valves, I'm thinking that when the car first started the lifters weren't pumped up they made a loud clicking noise, maybe now they are pumped up and making the valves too tight. We took a vaccum gage to the engine and there is no vacuum what so ever. Could this be due to tight valves. I am starting to think about dropping a 350 in it, which would be better but I don't have the money.
Old Jan 18, 2001 | 08:03 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
try loosening the rockers and starting it, not too much, just enough, does it sound really hard while turning over?
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Jan 18, 2001 | 08:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did this happen all of a sudden? No vacuum could be caused by a plugged exhaust/bad cat...even if the timing was whacked, i'd think you'd get some vacuum...
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
