Engine Light ON!!
Old Jan 13, 2004 | 08:31 PM
white91Z28's Avatar
Car: 1991 Camaro Z28
Engine: TPI 350
Transmission: 700R-4
Engine Light ON!!
It started yesterday...I just got up to 60-65mph and then the engine light came on... After class (an hour later) I started the car up and the engine light never came back on...When I got home I disconnected the battery to clear the computer. Then today once again when I got up to 60-65mph the light came back on...when I got down to 45mph the light went off...After class I went up to 65mph again and the light never came back on....
What would cause the light to come on...
Old Jan 13, 2004 | 08:44 PM
DJsyclone's Avatar
You got your car all confused.
Old Jan 13, 2004 | 09:59 PM
qwik92rs's Avatar
Car: 1992 Camaro Heritage Edition
Engine: 305 TBI
My car did the same thing at about 60-65 mph. It would come on and then turn off after I restarted the car. It did it for maybe a few weeks and then stopped. I'm not sure what was happening but it quit.
Old Jan 13, 2004 | 10:14 PM
llvll4l2c91350's Avatar
Re: Engine Light ON!!
check the codes. might be EGR fault.
any 1/4 mile times with that setup?
Old Jan 14, 2004 | 12:41 AM
Rob91GTA's Avatar
Car: 91 GTA
Engine: 5.0 TPI LB9
Transmission: 700R4 Auto
When my EGR wasn't functioning due to a vacuum problem, after cruising at highway speeds for a little while my check engine light would come on. Could be any number of things though.
Next time your light comes on don't clear the codes. I am not sure if your car is exactly the same as mine but I would bet it is. I jumped out pins A & B (top 2 pins on the right hand side of the connector) on the ALDL and that puts it in diagnostic mode. It then flashes your check engine light the codes the ecm has stored. It starts with code 12 on my car (diagnostic mode), so it does this: flash, pause, flash-flash. It does each code three times. If you don't do it this way the only other way is to have a shop hook it up to a diagnostic scan tool.
Hope that helps.
Old Jan 14, 2004 | 12:56 AM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
Thats weird, because my mom has the exact same problem with her VW fox. only its not just a light, it has a really annoying buzzer noise it makes too...
Old Jan 14, 2004 | 08:45 AM
white91Z28's Avatar
Engine: TPI 350
When I get home Ill check the codes if possible.
llvll4l2c91350, I have not been on a 1/4 mile track yet but ive been on an 1/8 one. My fastest time was 9.3 that was before most of the mods and before I rebuilt motor.
Old Jan 15, 2004 | 12:25 PM
white91Z28's Avatar
Engine: TPI 350
I just pulled the codes and they are 32 and 43.. Ive read that you can get a code 32 when you have a more free flowing exhaust...is their any truth to that? As for the code 43 I guess I will have to change out the knock sensor.
How come I got 2 codes at the exact same time?
Oh and if it makes any difference, the recent thing I had done to my car was put a new O2 sensor in about a month ago.
Old Jan 15, 2004 | 08:46 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Here are your error codes.
32. Fault in barometric pressure sensor circuit OR
Fault in exhaust gas recirculation valve diagnostic switch OR
Fault in electronic vacuum regulator valve
43. Low voltage at electronic spark timing circuit
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
