Helllp..... why does my car die
Old Jan 15, 2004 | 06:21 AM
rob roy's Avatar
Car: 1991 firebird
Transmission: auto
it onlly happens every once in awhile but when it does it gets annoying...it starts fine and i go some where. but when ever I turn it off ...like to fuel up.... I try to start it but it wont start it sounds like it aint gettin fuel but after I sit and wait about 10 to 15 minutes it starts right up .... this ever happen to any of u guys
Old Jan 15, 2004 | 06:45 AM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
When it doesn't start does it crank? If it doesn't crank, it sounds like you are having a heat soak problem with the starter...
Old Jan 15, 2004 | 01:26 PM
rob roy's Avatar
Car: 1991 firebird
Transmission: auto
well it does crank
it cranks it s little heart out. till I quit I just had the starter, and the fuel pump replaced
Old Jan 15, 2004 | 01:32 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
id replace the fuel filter first. theyre cheap and it can only help.
Old Jan 15, 2004 | 01:33 PM
rob roy's Avatar
Car: 1991 firebird
Transmission: auto
did that to
My friend said it may be the coil.... I have no idea what that is
Old Jan 15, 2004 | 01:41 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
no such thing as a heat soaked starter.
simply a starter that is too weak.
timing too advanced agravates the problem.
when you go to start a hot engine, if the starter is tuning the engine too slow and without enough power, when the spark plug fires before TDC, it ignites the air/fuel easily because the chamber is still nice and hot, so it drives the piston straight back down before it could reach TDC. that rotates the crank backwards.
the starter has to fight this, but a starter that is up for the job will be able to turn the engine over with enough torque to get the piston past TDC.
i had the same problem when i put a new 9.1:1 compression 350 in my car, replacing the 8.5:1 compression 305. and i re-used my old stock starter.
being that it is old and weak, it wouldn't start the engine hot, so i had to do one of two things
back off the timing, and lose power, or get a stronger starter,
i got a stronger starter.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
