383 Build - Input Wanted
Old Jan 16, 2004 | 11:17 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I'm putting together a stroker... so far the only parts I have are:
Eagle cast crank, GM roller block & lifters.
So, I'm trying to make a decision on what rods are best for this application, and I did some searches.
It seems like some of the popular choices are the Eagle H beam, Scat H beam, and Scat 4340 cap screw I beam.
Originally my plan was to go with the Scat 4340 I beam, the idea being that they're lighter and less expensive and probably strong enough.
But I'm being swayed toward H beam rods, and the reasons for that is mainly because they are apparently available "stroker clearanced".
I don't have any problem with clearancing my own rods. But if I could get a stronger rod and save myself some labor for just $100 higher price tag, it could be worth it.
So these are my questions about "stroker clearanced" rods:
- Is stroker clearancing a special option for any of the above mentioned rods, is it a special part #, or are all the H beam rods clearanced?
- Would a rod that is stroker clearanced out of the box clear ANY cam?
- There are some Eagle featherweight H beams out there, does anyone know anything about how these might be for my app?
One of my reasons for wanting universal out of the box "stroker clearanced" rods, is because I'm thinking it could make it easier to upgrade cams, should I want to do that. Also, easier to balance than a set of rods that have all been altered.
I realize too that there are a number of good American-made cap screw I beam rods out there which are also stroker clearanced, and feedback on those would be appreciated.
The crank I have is rated for 500hp, but I doubt that I'll be making more than 450hp.
I'm hoping my car will run in the low 12s.
Old Jan 16, 2004 | 12:42 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I used the Eagle SIR 6" I-beam rods. No clearancing needed.
Old Jan 16, 2004 | 01:06 PM
Car: '85 IROC
Engine: LB9
Some guys say they have to grind and some say they don't... Kinda hard to figure out.
Small BC cam?
Checked out your site... My car's in the infantile stages of that. Gotta have one!
Old Jan 16, 2004 | 06:52 PM
Car: '85 IROC
Engine: LB9
All the 383 guys outa town . . . or whut ??
Old Jan 17, 2004 | 10:55 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
The Eagle 3D H-beam stroker rods are clearanced. Not sure abt other stroker H-beams, but I would think they would be.
The Eagle H-beams will clear up to .600" lift cams. My LPE 74211 (.530/.560) cleared with plenty of room to spare.
Haven't heard anything abt them. I suspect they would be very pricey and not really needed for a street eng.
Old Jan 18, 2004 | 12:04 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
d00d not to sound like i'm spamming but i just found this awesome place selling 383 for so cheap you wont believe it. Its not a joke either, they are a machining shop in cali.
http://www.larrysperformance.com/data/assemkits.html
383 2 Bolt $995
383 4 Bolt $1100
now tlel me those prices are bad and i'll leave you alone but just check it out. They hare pretty cool. right now they havea full 350 Short Block already remanufactured for $349. cant beat that.
Old Jan 18, 2004 | 12:26 AM
joshwilson3's Avatar
Old Jan 18, 2004 | 12:27 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
well let me do a little consumer report lookups for you
Old Jan 18, 2004 | 12:32 AM
Old Jan 18, 2004 | 12:36 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
the difference is
As i think you meant assembly kits- thats where they give you the parts and you put it together yourself which saves you money.
Short blocks should be remanufactured
Assembled Engies i think are Rebuilt
Old Jan 18, 2004 | 12:38 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Also from what i can see nobody has complained about their products. But nobody has ever put in a review. All i can come up with is that some racers get their engines form them. I dunno though.
Old Jan 18, 2004 | 12:41 AM
Old Jan 18, 2004 | 12:43 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Balancing an engine is like balancing your tires.
If they are not balanced Performance will be severly limited.
Old Jan 18, 2004 | 12:45 AM
Car: '85 IROC
Engine: LB9
Thanks for the replies guys.
Eagle ESP 3-D .... Okay
Larry's Performance .... Bookmark that .
Have a good weekend
Old Jan 18, 2004 | 12:48 AM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
I'm thinking that a remanufactured engine is brought back to original specs meaning that they dont bore it out they keep it the same. They dont bore out anything. When yuo bore out a 350 .030 over its now technically a 355. SO there fore a remanufactured 350 would stay a 350.
italiano67
Dec 11, 2016 09:21 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
