couple of ?'s about Pro lightning heads
Old Jan 18, 2004 | 10:26 AM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
Alright here is the set of heads I am about to order http://www.protopline.com/223400080a.asp What I need to know is. Will my edelbrock performer intake work with these heads or do I have to get a 23*intake manifold....if I have to get a new intake who makes a dual plane 23* intake, I know of a few single planes but i dont' want one of those..Last question where can I find these for the cheapest price?
Old Jan 18, 2004 | 10:31 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
23° has nothing to do with the manifold. It refers to the angle that the valves are canted with respect to the perpendicular to the block. It is the stock angle.
Your Performer will work with them, but something with a bit more flow would probably be more appropriate. Not alot of sense in getting good flowing heads and then choking them with some other part.
Old Jan 18, 2004 | 10:43 AM
Car: 89 camaro RS
with in a couple of weeks after I get the heads I am upgrading to a performer rpm intake with a comp cam 268* extreme energy cam and hedman headers
Old Jan 18, 2004 | 10:56 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Those heads with that manifold should make a nice torquey street engine. A bigger intake will give you a little more horsepower at the expense of some torque.
Old Jan 18, 2004 | 11:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That group of parts would make a good match, especially if you use 1.6 rockers.
Old Jan 18, 2004 | 06:34 PM
rjmcgee's Avatar
I ordered 180 cc heads and it was going to take a long time to get them so I went ahead and got the 200cc. Don't know if this is common or not but I thought I would give you a little heads up. Am real happy with them and also have the RPM airgap intake and a simular cam to what you are choosing, just one step bigger. You should be happy with your combo.
Old Jan 19, 2004 | 12:15 AM
Car: 89 camaro RS
Do you have any idea how much horsepower you are pushing...Cause I am also toying with the idea of using a 383 stroker bottem end to go along with all those other parts.
Old Jan 19, 2004 | 07:53 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I can't tell you very much that would be helpful on that. But I'm wondering, did you compare the proline 23* 180s to the vortec replacement? If so what influenced your decision?
BlueIroc-Z
Jun 9, 2019 03:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
qz6lwp
Aug 20, 2015 08:10 PM
Dialed_In
Aug 20, 2015 01:45 PM
