Roller Pushrods
Old Jan 19, 2004 | 08:19 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Roller Pushrods
Hey all what is the difference between the pushrods used in the Corvette L98 with the guide plates and the L98 (iron heads) with roller cam and no guide plates. I understand any time we use plates we use hardeded rods. Did the vette have hardened rods?
Brian Felts
Old Jan 19, 2004 | 08:40 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Are you sure the Vette(113) heads came stock with guideplates? I thought GM went to SA rockers in '86 or so for everything.
Old Jan 19, 2004 | 08:46 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I just went to Scoggin Dickeys website and looked this:
http://www.sdpc2000.com/cart.asp?act...id=277&pid=147
Notice it says "must use SA Rockers"..
Could it be the ones you have, were worked on by someone else?
Old Jan 19, 2004 | 09:21 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
The guide plates in L98 aluminum heads are merely for assembly purposes ONLY. They arent hardened, and can NOT be used with non-self aligning rockers.
Old Jan 19, 2004 | 10:08 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
And so the mystery is revealed.
Now why the heck would you need guideplates for assembly?
Old Jan 20, 2004 | 03:17 AM
Well thats my problem I am using S/A rockers and they are rubbing on the retainers. I think the ridges where the roller hits the valve is letting it too far down on the valve retainers.
Brian Fetls
Old Jan 20, 2004 | 08:50 PM
NHRAK188's Avatar
Since we are on the subject of S.A Rockers..Anyone know if the following head required a SA Rocker GM#14101128(I believe it is a 86-87 Corvette Alum Head)
Thanks.
Old Jan 23, 2004 | 03:06 PM
Yes, they should be S/A as well. But, if you put in guide plates and hardened pushrods, you can run non-S/A's.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
