roller pilot bearing
Old Jan 22, 2001 | 07:47 PM
jmon92conv's Avatar
Going to replace my clutch and the guys at my local Chevy shop said to use it. Anyone ever use it, does it fit OK?
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC, 3.42's
when it warms up Edelbrock STB maybe springs
Old Jan 22, 2001 | 08:04 PM
ede's Avatar
ede
yes and yes, it's lot better than a bushing
ICON Motorsports
1st & 3rd
Old Jan 22, 2001 | 08:10 PM
jmon92conv's Avatar
Thanks ede, I thought so but was just making sure.
Jeremy
Old Jan 22, 2001 | 08:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Some of these cars even came stock with the roller bearing instead of the bushing. Definitely the way to go.
ICON Motorsports
Old Jan 22, 2001 | 10:00 PM
Vader's Avatar
92,
Don't forget to pack it with grease! (Long story, and pulling a toasted bearing is NOT fun.)
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 22, 2001 | 10:04 PM
Guest
Guest
Posts: n/a
Yea, that and be nice to it
If you smash it up or get it in there crooked, it will take it out in short order.
Old Jan 23, 2001 | 06:19 AM
Pat Hall's Avatar
I have one in my 69 and it works great. Like the other guys said, just make sure you press it in nice and straight. As far as greasing it goes, I used disc brake wheel bearing grease on mine when I put it in. It's nice and thick and lasts longer than standard wheel bearing grease. Don't go overboard on the grease though, or you'll end up slinging grease all over your brand new clutch disc. A light coating on the roller bearings should be plenty.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Jan 23, 2001 | 08:06 AM
jmon92conv's Avatar
The one I bought from GM has grease in it. Should I add some to it. It looks like the bearings hasve a nice coat to it.
Jeremy
92 Z conv
5-spd B&M shifter
Old Jan 23, 2001 | 12:34 PM
Guest
Guest
Posts: n/a
The amount of grease that comes on them isnt enough, I would put some more in the center of it after you install it, and that should be good then.
Old Jan 23, 2001 | 01:18 PM
jmon92conv's Avatar
thanks everyone. I can always count on this board.
Jeremy
92 Z conv
5-spd B&M shifter
KO1
16
Oct 15, 2015 05:00 PM
gord327
Oct 3, 2015 01:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
