Radiator Fan
Old Jan 21, 2001 | 06:38 AM
FiReBReTHa's Avatar
Radiator Fan
I have a 91 single cooling fan, can i swap it for a dual fan from a 92 trans am?
I had mine squeezed so now its makin scrapin noises,
My cars a 91 firebird 305
Any info is appreciated,
THanx
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Jan 21, 2001 | 08:37 AM
ede's Avatar
ede
it should fit if that's what you're asking. you'll have to add the senser for the second fan or wire it on all the time. if you don't want to change fans i think you can "adjust" the one you have to not scrape.
ICON Motorsports
1st & 3rd
Old Jan 21, 2001 | 01:00 PM
FiReBReTHa's Avatar
nopers, the one i got is bogus, bad,
hmm.... okay, so the harness that i have right now will plug N Play with the new #1 fan, And Then Ghetto rig a switch for secondary?
Old Jan 21, 2001 | 10:17 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
You can always run another relay off the original fan relay to power the second fan. Unless you want to control it all the time. I wouldn't recommend wiring both fans off the same relay or you'll smoke it.
Old Jan 21, 2001 | 11:07 PM
FiReBReTHa's Avatar
hmmmm.... a little bit confused, i was sure if the harness that i have right now, will just fit into one of the fans, so whenever the puter needs it, it will turn on fan #1
But if its a hot day, and i feel it needs to be cooler i can turn on #2 fan, and #1 fan will act as usual
Old Jan 22, 2001 | 10:37 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
basically yeah. well...thats what they are saying...i dont know if the single and double fans have the same connector.
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Jan 23, 2001 | 11:09 AM
Desert86Roc's Avatar
Here you go... http://www.metzcon.com/racing/dualfans.htm
Mike Metzler (Desert86Roc)
Mike@SpeedworldMotorplex.com
[*] Webmaster: SpeedWorldMotorplex.com[*] Click Here For My Racing Page[*]86 IROC 305 TPI (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.365 @ 86.785 mph (uncorrected, Headers, no NOS)
Old Jan 23, 2001 | 01:41 PM
FiReBReTHa's Avatar
HERES WHAT I WANTED:
http://cgi.ebay.com/ebaymotors/aw-cg...175181&r=0&t=0
sorry caps
Old Jan 23, 2001 | 07:40 PM
Go for it.... you have most of the components right there...if the motors are good. Even if they are not, the fan blades and shroud with brackets more than make up for it.
sheachopper
Jul 31, 2019 11:27 AM
Fanatic1074
Oct 2, 2015 03:47 PM
