Stupid V-belts!!
Old Jan 23, 2001 | 05:33 PM
Wolfcoast's Avatar
Stupid V-belts!!
Ok. I've got an 84 TA and an 84 Z28.
I recently kept having problems on my Z28 with the alternator squealing like crazy. I switched it to the serpentine setup from a 91 Z28 and now it works fine.
I just took back my 84 TA from the person that was buying it from me due to non-payment.
The TA is doing the same thing. No matter what tension I put on the belt, it squeals.
The alternator is a new (rebuilt) one from the parts store. It doesn't squeal much but now it looks like it's not charging the system.
It doesn't look like the pulleys are misaligned at all.
Anyone have an idea???? This is getting really frustrating. And I can't afford to get another serpentine setup for awhile.
The TA is an LG4 Automatic. The Z28 is an L69 5 spd.
Thanx.
Randy
Randy
84 Trans AM LG4, 700R4 T-tops
1984 Z28 L69, 5 Spd, T-tops
"Don't sweat the petty things...Just pet the sweaty things"
Old Jan 23, 2001 | 05:54 PM
GearHead1973's Avatar
What brand belt are you using? If its a Gates brand belt they do squeal. If its a Napa, Carquest belt its a Gates belt. Also gates brand belts tend to stretch more than other brands. I had this problem on a Toyota with a Gates belt and I switched brands of belt and it went away. I buy Dayco brand belts I think they are better quality.
Old Jan 23, 2001 | 06:37 PM
irocbsa's Avatar
I had this same problem after replacing my alternator. Ends up it just wasn't tight enough. This could be related to the fact that the system is not putting out enough power. Grab it with both hands and pull that sucker back as hard as you can. Have someone else tighten the bolt. Next time you take off the alternator mark the placement of the bolt so you know where to place it at when reassembling. If you have already done this, disregard and follow preceding post.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jan 23, 2001 | 09:07 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
THe best thing I ever did was replacing the V-belt on the alternator with the ribbed setup from a newer LG4. (Similar to serpentine, but just for the alt. and water pump) I got my pulleys from (I think) a '86 Grand Prix, but they were on almost all 86 LG4's and I think maybe even 85 V8's in general. Look around at a salvage yard!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is STILL in shop! (Waiting for my to buy the rods!)
ASE Certified Master Tech
Starting to look like the Kicker poster child!
Old Jan 23, 2001 | 11:27 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I had the same thing happen to my car! The first time it was the belt was worn out so I replaced it! The 2nd time was right after I replaced the alternator and I found out it was just not tight enough! The two handed method might work but it didn't for me!! I ended up taking an L-shaped lug wrench and putting it through the hole in the bracket and pushed on it.....got great leverage to tighten it REAL TIGHT! Now it's perfect!
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Hedman Shorty Headers, pocket ported 64cc or 76cc heads(undecided), ported intake, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
djmarch
Oct 2, 2015 10:41 PM
83ho87gn
Sep 26, 2015 08:49 PM
spartanreaper
Sep 25, 2015 07:22 PM
83ho87gn
Sep 24, 2015 08:58 AM
gta892000
Sep 16, 2015 12:37 AM
