how to keep crank from rotating w/ engine on stand
Old Jan 25, 2004 | 03:19 PM
llvll4l2c91350's Avatar
need to loosen the crank pulley but everything keeps turning. the flywheel is off so i can't hold it with that. and i'm working without air tools.
TIA
Attached Thumbnails how to keep crank from rotating w/ engine on stand-dscn0396-small-.jpg
Old Jan 25, 2004 | 03:48 PM
launchpad's Avatar
socket with breaker bar and hammer. A sharp blow should work on the bolt.
Old Jan 25, 2004 | 03:54 PM
waterstrw's Avatar
Car: 87 Iroc-Z
Engine: LB9
You can put two of the flywheel bolts back in across from each other and have someone hold a prybar across them while you looses the bolt.
Old Jan 25, 2004 | 05:28 PM
ede's Avatar
ede
or pull the oil pan and let the crank spin around and bind on a hammer handle
Old Jan 25, 2004 | 06:54 PM
thanx guys i did the flywheel bolt method and worked fine. i'll keep workin on it tomorrow.
Old Jan 25, 2004 | 06:55 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
not trying ot be nosey =] but what ya doing to her?
Old Jan 25, 2004 | 07:02 PM
Vader's Avatar
Probably a total rebuild - new crank, pistons, etc. After all, it DOES have a Fram filter screwed on there, so it's probably toast.
I was gonna suggest a 2x4 between a crank throw and the case, but ede beat me to it.
Old Jan 25, 2004 | 07:09 PM
LOL
yea the fram filter kinda worried me but i got this L98 block and heads for cheap (80K miles) so i couldn't pass it up. planning on sending it to the machine shop this week and rebuilding it with a lil better than stock parts then putting it in my 91 Formula. i got parts all over my garage plus another complete Formula that i'm using for parts as well.
Old Jan 25, 2004 | 07:37 PM
OMINOUS_87's Avatar
THIS IS NOT A JOKE, FRAM MAKES THE WORST FILTER ON THE MARKET, DO NOT RUN EM, EVEN IF THE PARTS STORE IS GIVING EM AWAY @2_FOR_1.
Old Jan 26, 2004 | 02:03 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
damn... i was under the impression fram was a good oil filter. why do they suck so bad? lol (maybe thats why i blew my engine? lol)
Old Jan 26, 2004 | 03:38 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...+filter+review
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
camarohelp
Sep 22, 2015 03:19 PM
