Stock 350 Compression ???
Old Jan 26, 2004 | 01:14 PM
85black&gold's Avatar
Car: 1987 Trans AM GTA
Engine: Vin Code "8" V-8 350C.I.
Transmission: 700-r4
I checked the compression on my 350 and I got 120? Is that low good or high?? Remenber it is completely stock.
Old Jan 26, 2004 | 02:32 PM
MdFormula350's Avatar
https://www.thirdgen.org/techbb2/sho...mpression+test
Old Jan 26, 2004 | 02:58 PM
but my question still stands.....is 120 too low. Although your links did answer a couple of my questions. THANKS
Old Jan 26, 2004 | 03:14 PM
StealthElephant's Avatar
Car: 87' Iroc
120 sounds low....you gotta do all 8 though, and compare them.
Old Jan 26, 2004 | 03:27 PM
Ye I checked all of them and they are all about 120.
Old Jan 26, 2004 | 05:50 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Moved to Tech/General Engine.
Old Jan 26, 2004 | 08:27 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Sounds about right if you have a 7.8:1 smog motor. On the other hand my cammed 1983 9.5:1 305 has 185 psi in every cylinder. Are you fully opening the throttle while cranking the engine?
Old Jan 26, 2004 | 09:32 PM
Car: 87' Iroc
For a 350, 120 sounds low, I mean, my 350 (granted I built it to my own specs) was pulling 190-200PSI per cylinder. 120 just sounds low from what I've seen...most people are around or above 150, even with alot of miles. If the engine runs strong and doesn't gulp fluids though, maybe thats just your engine.
Old Jan 27, 2004 | 05:04 AM
ede's Avatar
ede
the number doesn't mean much it's the differance between numbers that matters
Old Jan 27, 2004 | 08:17 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
I agree you should not see more than a 10% difference between cylinders. 120PSI means that you should not be below 108 psi or abobe 132 psi in any cylinder. My 1983 305 has 170,000 miles on it and still puts out 185+/- 2 psi in every cylinder with a fair sized cam. Another check would be to put a teaspoon of oil in the cylinder then do the test. If the numbers come up alot you most likely need rings.
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
BBSDesigns
Aug 11, 2015 07:39 PM
