plastic welding?
Old Jan 27, 2004 | 06:59 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
plastic welding?
Has anyone tried one of those plastic welders? The mount on my dash to the frame broke and now my dash rattles around
Old Jan 27, 2004 | 07:26 PM
DJsyclone's Avatar
You mean the syringe type with two tubes, and you mix the two together? I've used it. Works great. Hardens fast and permanent.
Old Jan 27, 2004 | 08:55 PM
dans82bird's Avatar
Engine: 302
no I actually saw some sort of heat thing, it looks like a big retarted soldering iron was wondering if anyone ever had any luck with one
Old Jan 27, 2004 | 09:49 PM
Vader's Avatar
Yes, I have. If you have adequate space for the filler material bead, they do an excellent job on ABS, PVC, polycarbonate, and even some styrene if the base material is thick enough. Most dash and interior structural plastic parts ar GRP with an ABS base, and can be repaired easily with plastic welding. Just remember that you don't want to weld so that you have to remove the filler, or the weld will be weakend. Do most of the repair on the reverse, or hidden side if you can.
Old Jan 27, 2004 | 09:54 PM
Vader's Avatar
One thing they might not tell you in the discount/import tool catalogs that sell teh low-cost versions of plastic welders is that you'll need an air compressor to operate it.
Old Jan 27, 2004 | 10:20 PM
ronterry's Avatar
Car: '94 Corvette
hmm I would use a liberal dose of hot glue...
Hot glue rules, hot glue rules, it can hold all your tools, awww.
(I guess I'm not a good song writer )
Ron
Old Jan 27, 2004 | 11:02 PM
dans82bird's Avatar
Engine: 302
Vader thanks again; I think your knowledge is infinite :hail:
Old Jan 28, 2004 | 10:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It only seems infinate to us mere mortals...
MrPackstin
Oct 25, 2017 08:09 PM
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
