Race motor 354ci???
Old Jan 28, 2004 | 07:37 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
Race motor 354ci???
I am thinking about running a road course around here that has a cubic in limit of 366ci. I have a spare 400 block and can get a 283 crank, if my memory seves me, the 283 is 3.25 stroke, for 354 cu in. I know it would be expensive but would a engine of this sort be feasable??? Or should I just look at 350's??
Any and all comments are welcome. I almost think myself I'm off my rocker.
Later
Spud
Old Jan 28, 2004 | 07:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 283 has a 3" stroke.
The 327 has a 3.25" stroke.
Yes it will work, and has been done. Obviously you need a large-journal 327 crank, and a set of main bearing spacers; you can use rather long rods (longer than 6") if you want to, but almost any combo will require custom pistons.
Old Jan 28, 2004 | 09:07 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Correct me if I'm wrong RB, (seem to be on a roll today) but will a 307 crank work? They're usually easier to find, and cost a heck of a lot less also.
That would give you 352.5 cubic inches with the block bored .030" over.
Old Jan 28, 2004 | 09:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're not wrong at all!!
Only thing is, those are all cast, and usually poor quality control castings at that. They would work just the same, as far as working goes, but would sort of defeat the whole idea of getting a little more rev capability than a normal 350.
Old Jan 29, 2004 | 07:17 AM
spud's Avatar
Engine: 400 & 355
What would you think the power potential would be reving it to 8000?
It would most likely be using the IE 215's from the 400?
John
Old Jan 29, 2004 | 12:41 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Ill be able to tell you this summer. I can tell you it runs beautifully and has outstanding throttle responce
Heres the 352ci in my dads garage back in Michigan. 400 block, 327 crank, 6.125" rods, 12.5:1, Iron eagle 215s.... Im building a 400 with my block though
Old Jan 30, 2004 | 07:58 AM
spud's Avatar
Engine: 400 & 355
What is your dad planning on putting it in?
And what kind of pistons did he use?
John
Old Jan 30, 2004 | 08:21 AM
SweetS10v8's Avatar
Engine: L98 & 355ci
John
Im attaching what it wil look like and a pic of the car. He used JE/SRP pistons.
The car is legally mine, but he just signed it over to me because of his bad health, and Im the only one who enjoys vehicles and if something happens to him he doesnt want it sold. I will be swapping in the 352ci for him this summer. I will report on comparision to his current motor.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
Cacike
Aug 27, 2015 05:10 PM
Randomtask2
Aug 26, 2015 03:34 PM
86White_T/A305
Aug 17, 2015 12:16 AM
