How will a H-pipe affect sound and performance?
Old Jan 26, 2001 | 11:46 PM
gsmann's Avatar
I have an 86 transam w/ 350, cam, headers, custom chip, true dual exhaust, etc.
Since i don't have an H-pipe now, how will it sound and perform if i put one in?
thankss
Old Jan 27, 2001 | 12:50 AM
3rdGem's Avatar
As I recall from an earlier post, you have "true duals", and your pipes are essentially side-by-side, correct? To feel the effect of an "H" pipe, your pipes must be separated by a least a foot (along both sides of the tranny, usually), and installed aft of the tranny crossmember. Once installed, you will gain an increase in low-end torque. Your set-up should be: headers (straight out), cats (each side), straight pipe, H-pipe behind tranny crossmember, pipes to muffler, to tail pipes. Hope this helps!! Anyone else?
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
Check out the newest f-body site: http://www.lastgen.com/
Old Jan 27, 2001 | 02:17 AM
Gta-Paladin's Avatar
Yes duals are required for an h pipe change your y pipe if you've already changed your exhaust if you have headers make sure the y pipe will bolt up
Blue419
Sep 10, 2015 01:03 PM
64goatman
Sep 9, 2015 01:09 PM
scottmoyer
Sep 7, 2015 07:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
Formula_88AE
Sep 3, 2015 01:47 PM
