smoke from the emissions box after installing chip.
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I have an interesting problem.I get a bunch of white smoke from the emissions box area. It happens a little after I start the car up. I only notice it if I let the car stands still.It smokes for a while and than it stops.No SES light and no performance loses.It just smokes up is all!!!
The first time I noticed it is right after I installed the Hypertech chip.
Now it happens once in a while. Not a regular thing. Seems to happen more when it's really cold out.
Anyone have this experience?
Any help is appreciated.
1990 Formula
Fatory:WS6-TPI-305/Dual Cat/5 Speed.Aluminum Drive Shaft.
Mods:SLP air foil,K&N Filter,All Accel ignition parts,Hypertech Thermomaster chip,Stat,Fan switch.Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce clutch.`
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Sorry, shoud have been more specific.
I mean that black plastic box that sits on the passanger side of the engine.Not sure what it's called.
That woudl be the air diverter valve. I'd say take the plastic cover off and have a look. Maybe one of the hoses came off or it's cracked or something. Try to see where the smoke (or vapor) is coming from.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
92 Z28 L98 350
