HELP! dropping engine in....
Old Jan 28, 2001 | 10:06 AM
CrazyRob75's Avatar
I'm in the middle of putting my 454 in my camaro. I need to know what the little capacitor/conddensor that sits behind the carb hooks up to. The wire ( brown) is just dangling there and I don't remeber it being like that. Th car is an 85 berlinetta LG4, carb. The guy that had the car before me took out the air conditioning, added an alarm, etc. so there are a few wires along the firewall that go nowhere.I need to know what this little condenser thingy does, what does it wire up to, and what would happen if I don't hook it up at all. Thanks in advance to everyone that replies
85 Berlinetta Iroc exterior Lg4 305 best e.t 14.4 street tires naturally aspirated....installing/ rebuilding 450-475 HP 454....YAHOOO!!!
Old Jan 28, 2001 | 10:33 AM
ede's Avatar
ede
i'm not 100% sure but i tihnk it goes to the blower motor or something related to it.
ICON Motorsports
1st & 3rd
Old Jan 28, 2001 | 11:34 AM
Vader's Avatar
Rob,
The cap was likely there as a surge suppressor, and my guess is that it was in the circuit for a throttle kicker/idle solenoid associated with the air conditioning.
If you don't connect it to anything, probably the worst problem you'll have is some noise in the radio when the AC turns off.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 28, 2001 | 01:00 PM
CamaroMike's Avatar
You sure that is'nt the Tach filter that bolts to the back of the drivers side head and plugs into the distributor?
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 28, 2001 | 03:09 PM
CrazyRob75's Avatar
I'm such an idiot. After I started hooking things up I realized it was exactly what Camaro Mike said. I had spliced an aftermarket tach in and when i dug the wire out I realized the BROWN wire was missing. I put 2 and 2 together and there you go problem solved.
By the way, the previous owner bolted it to the intake just behind the carb, so that would be why it wasn't on the back of the head. Man, simply things that you should know
fly out the window sometimes .
Thanks alot guys,
Jake_92RS
Jan 28, 2020 10:37 PM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
